20 Most Recent Kodak EasyShare Z710 Digital Camera Questions & Answers
The hood you buy needs to be the same as the inner ring on your lens. If you look at the inside of the lens ring or on the outside of the lens it will tell you what size filters will fit your lens. If the 52mm is too small or too big you should be able to find a adapter for it so it will fit. Try going to B&H photo website. They have tons of photography items. Hope this helps.
Kodak EasyShare... | Answered on Jun 17, 2015
Outside of camera settings/preferences controls, the most common is one or more of the connector pins inside the camera are out of position/broken/disconnected. if it is a bent pin, I use a tiny screw driver to straighten them.
Kodak EasyShare... | Answered on May 23, 2014
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa ( http://picasa.google.com ).
Kodak EasyShare... | Answered on May 16, 2014
When this happens, consider the battery lost. It must have had a reaction inside that made it hot and that caused it to deform. Or it leaked and is oxidised.
So everything you can do to get it out without damaging the camera is ok. You have to buy a new battery. But before going through lots of trouble, ask what a new battery will cost. If it is more expensive than a new camera (with battery) go for the new camera.
Kodak EasyShare... | Answered on May 12, 2014
It may be time to buy a card reader for your computer. You can get one at a department or electronics store for not much more than a cup of coffee.
Kodak EasyShare... | Answered on Dec 11, 2013
Rather than blame your husband, simply order another power supply cord from Amazon or eBay. Problem solved!
Kodak EasyShare... | Answered on Nov 04, 2013
Try formating the memory card using the camera's Menu - select format memory card.
Kodak EasyShare... | Answered on Feb 28, 2013
You have a censor failure or other related problem, needs to go in for repairs.
Kodak EasyShare... | Answered on Jan 24, 2013
Kodak EasyShare Z710 Digital Camera Logo
220 questions posted
Top Kodak Cameras Experts
Ekse
Vitally Alcher
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Kodak Camera Expert? Answer questions, earn points and help others
View Most Popular
EasyShare Kodak
  • EasyShare Kodak
Most Popular Question
kodak z710 cannot transfer photos onto
  • Cameras
