20 Most Recent
Samsung 941BW LCD Monitor Questions & Answers
Hi.
I have intel graphics card
I would suggest you go to the Intel web site and download the specific drivers for your graphics card. Often, the drivers that come with computers do not carry the latest revision for your card.
After installing the drivers, see if you have the 1440x900 resolution which is native to your 941BW.
Good luck.
Semper Fi,
Z
Syncmaster 941bw coming up blank
Hummm. Try to unplug everything, reconnect, than restart. If not working, try to plug your monitor on a different computer to diagnose what is wrong, the computer or monitor. It could also be your graphic adapter, verify that it is firmly attached to the motherboard.
Lastly, replace the defective part.
I have a dell laptop that I want to add a second
Hi there, if i read you correctly you are trying to connect external monitor on laptop. As you use old Monitor for this you can probably establish only VGA connection . For this you dont need any special drivers if you use VGA external connector on laptop. You just need to find out right combination on keyboard to activate external monitor to be activated or right click on desktop then properties and display option multiple displays. Of course when you manage to activate mode for external screen please use lower resolution like 1027*768 for second display aka monitor to test .Cheers
I just upgrade to Window 7, to my ACER AspireOne
As of now, there are no Windows 7 drivers for that monitor.
Here is the Vista driver:
Acer X163W Vista 32-bit Driver
You can try installing this in Windows 7 using compatibility mode and see if it works. Otherwise, just try to contact them directly or try and submit a query about it.
Samsung Syncmaster 941BW No power
My Samsung 941BW would not display, only a flashing blue power button; no-onscreen menu, nothing. The internal power supply had 9 CapXon brand capacitors. Two (C109 & C110) were bulging. I replaced all except the huge 100uF 450V Cap and Presto-Magico....the monitor works fine now. If you are comfortable replacing circuit card components, go for it! Thanks for the tip, budmrtn!
Samsung 941bw monitor, no power
YOU NEED TO REPLAC THE T-CON BOARD, ITS A COMMON PROBLEM. YOU CAN GET IT AT GOLDENLEPRICON. COM PART COMES WITH INSTRUCTIONS.
Flickers for several minutes at
It may have dying power supply due to bad DC filter caps in the power supply, it will get worst and more damages may occur.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Getting behind the lcd
I don't recommend the taking a lcd apart unless you have had some time in a shop doing it. replacement of the lcd unit is much preferred and easy E bay may have what you need just take the model and manufacturer and do a search, that way you can just replace the lcd unit and I feel confident that will work
Maquina de lavar Samsung wf90f5e5u4w
ENGLISH ONLY please.
Samsung washing machine wf90f5e5u4w
Hello good afternoon, I want to ask for help, I have a faulty module and I wanted to ask if you have the electronic diagram for the Samsung DC92-01240C washing machine, the machine model wf90f5e5u4w, I would really appreciate it if you could, thank you. greetings Antonio Paulo
Steam Wash, Washers Support ' Samsung Care US
Samsung
https://www.samsung.com > washers > front-load > ste...
Get the latest drivers, manuals, firmware, and software. Learn more. Request repair service. Arrange for a service visit at home, schedule a walk- ...
https://www.google.com/search?q=Samsung+DC92-01240C+service+manual
12/4/2023 10:19:25 PM •
Samsung...
Answered
on Dec 04, 2023
