20 Most Recent Acer AL2216WBD LCD Monitor Questions & Answers
Emachine - no signal
This isnt a one step fix. Power off unit then while powering on tap F8 key to get menu with option to boot to safe mode. If this works could be a driver or malware issue which can sometimes cause windows to come up in safe mode but not normal mode. This is only a start not a solution.
12/6/2017 8:04:23 PM • Acer AL2216WBD... • Answered on Dec 06, 2017
2answers
Al2032w
Hello,This usually indicates that the filter capacitors in the power supply are not working right. When the unit is turned on they should build up a charge that lets the board power up the monitor but when they start to go out it takes longer and longer to get the charge built up. Here is a link to information on rebuilding the power supply board by replacing the capacitors, this should get you back up and running.www.ccl-la.com/catalog/product_info.php?products_id=288
12/15/2012 1:24:16 PM • Acer AL2216WBD... • Answered on Dec 15, 2012
LCD Monitor Acer AL1717 shtting down problem
Aside from the capacitor and IC, there's a relay that you need to change. You need to locate that defective relay on the PCB and replace it.
It would be best to consult the manufacturer of the LCD and get the exact part number of it.
Have a great day!
Regards,
Firesnake09
11/15/2012 8:51:30 AM • Acer AL2216WBD... • Answered on Nov 15, 2012
Acer AL22 Has no image for 1 Hour. Then is OK.
Hello,That is a common symptom of a failing power supply board. The filter capacitors start to go bad and the power supply can not stabilize and start correctly, after the capacitors are powered up for a while they can hold a charge and the power supply finally gets going. Here is a link to a repair guide for that model.http://www.ccl-la.com/blog/index.php/repairing-the-acer-al2216w-lcd-monitor/
10/27/2012 11:24:42 PM • Acer AL2216WBD... • Answered on Oct 27, 2012
2answers
Monitor was humming one day, then the next day, it
Chane the Capacitor on panel circuit
3/5/2011 10:18:48 PM • Acer AL2216WBD... • Answered on Mar 05, 2011
Monitor screen indicates No Signal
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error hope this helps don
2/15/2011 10:31:22 PM • Acer AL2216WBD... • Answered on Feb 15, 2011
Two monitors blank, but on
<table x:str="" style="border-collapse: collapse; width: 124pt;" border="0" cellpadding="0" cellspacing="0" width="165"><col style="width: 124pt;" width="165"> <tr style="height: 14.25pt;" height="19"> <td style="height: 14.25pt; width: 124pt;" height="19" width="165">http://www.wholesaleeshop.com.au/LCD-Monitor/10.4-inch.php</td> </tr></table><br />I wish you problem can be solution. <table x:str="" style="border-collapse: collapse; width: 54pt;" border="0" cellpadding="0" cellspacing="0" width="72"><col style="width: 54pt;" width="72"> <tr style="height: 14.25pt;" height="19"> <td style="height: 14.25pt; width: 54pt;" height="19" width="72">&lt;a href="http://www.wholesaleeshop.com.au/LCD-Monitor/10.4-inch.php"&gt;10.4 inch LCD Monitor&lt;/a&gt;</td> </tr></table>
8/30/2010 6:26:31 AM • Acer AL2216WBD... • Answered on Aug 30, 2010
Monitor not working
make it sure your cable is plug properly and clean your raM..
8/20/2010 4:15:23 AM • Acer AL2216WBD... • Answered on Aug 20, 2010
2answers
Acer AL1916 Monitor went black and beeps
It sounds like you have a monitor with a common problem, this series of Acer monitors are known to have this issue. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of he monitor. When the capacitors blow out they also damage the driver MOSFETs. If you are good at electronics repair/soldering you can usually fix he problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts, replace any that look like the pictures and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. I have a repair guide for this model, check my web site for the guide. Repair parts kits are also available for $16.00 If you don't want to try the repair yourself we offer a repair service for $35 plus shipping. If you are not going to repair it we will buy it from you for parts, we pay $30 for dead/as-is units.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
5/15/2010 10:06:02 AM • Acer AL2216WBD... • Answered on May 15, 2010
Asus AL2216W top half screen got darker. Lamp problem ?
When the lamps are bad, the screen will shut down if the inverter cricuits is sensing open (lamps will not fire up and conduct, or lamps are drawing too much current). You should open it up and inspect the caps in the power supply first, lamps in this monitor are ntoeasy to replace (screnn will to be complete,ey disassembled.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
4/24/2010 1:04:52 AM • Acer AL2216WBD... • Answered on Apr 24, 2010
My Acer AL2216W suddenly displays a blurred
Please verify that you are running your PC video card with native resolution of this monitor, 1680x1050 @60Hz for best picture for this monitor.
Unless you may have problem inside the monitor or the video card itself, so try this monitor on another PC also.
4/16/2010 9:33:33 PM • Acer AL2216WBD... • Answered on Apr 16, 2010
My acer al2216w doesn't allow me to change
how r u tryin change???
3/5/2010 2:03:22 AM • Acer AL2216WBD... • Answered on Mar 05, 2010
Icons on top of each other. start button in wrongplace
lcd monitors have a auto resize button...
but for your icons... you can do this...
right click in any part of the window then arrange icon then choose if you want for name or etc.
2/11/2010 2:20:24 PM • Acer AL2216WBD... • Answered on Feb 11, 2010
2answers
Monitor screen is showing sideways....in other
If your video card has installed software go into the application and find the display property you should be able to change it through there. If not find the display button on your monitor and try that feature.
12/29/2009 6:36:19 PM • Acer AL2216WBD... • Answered on Dec 29, 2009
Acer AL2216WBD LCD Monitor Logo
Popular Tags
51 questions posted
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
View Most Popular
AL Acer
  • AL Acer
Most Popular Question
acer al22 no image 1 hour ok
  • Computers & Internet
