20 Most Recent
Olympus FE-240 Digital Camera Questions & Answers
Al prender mi camara digital
When this problem occurs Protec. Escr., Just enter the tools menu and find "Format" and voila, the camera returned to work usually remains
I cannot transfer my pics
Try NOT connecting your camera to your computer.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use iPhoto or any other photo management program.
Message on my screen: couver carte. It is a new
"Couver Carte" is french for basically, SD Card cover is open. Your first problem is that the camera is setup to language "French" and by using the menus in setup, of the icons if displayed, you can change the setting to "English"You can attempt to take it to a repair shop or disassemble the camera yourself, either way there are reports that a small lever might be broken. This lever presses a button that then sends a signal to the camera to let it know that the card cover is closed and is ready for use. Personally, I would let the techinician attempt to fix it or purchase a new camera, as I have seen a lot of complaints for this brand on this simular topic
Protec. Escr. ¿qué significa esto?
When this problem occur you need to set the memory card unlock or not
protected.
Remove the memory card from camera and you can see a small button in
the memory card, so you need to slide that to set the memory card unlock
or not
protected.
Can't connect to computer. it's
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
Buenos dias tengo un problema
Desde el menú de la cámara formatea la memoria.
Si no funciona, formatéala desde la PC.
Si no se formatea en una PC, la memoria está defectuosa. Compra otra.
I have a window7 notebook
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use Windows Photo Gallery or any other photo cataloging program.
The cover on the battery
I imagine the only way to obtain a proper part is to send it to an approved Olympus service centre, hopefully under warranty (though I expect they would not regard this as covered).
The camera must have some way of telling that the door is open. Is there a tiny switch on the catch, or behind a little hole that something on the lid poked through? If so, perhaps you could jam it. Maybe there is a reed switch that was activated by a magnet in the lid.
I don't really see why this should be an issue for the camera to worry about, as long as things aren't falling out. My high-end Lumix pays no attention to hatches being open.
