20 Most Recent
Samsung LN-S4095D 40 in. LCD HDTV Questions & Answers
My LN-S4095D (3 years old), only works for about
Hello Dsidneysis,
It appears that this failure could be in the power supply due to swelling/ bulging capacitors in the power supply.
Check the link below to find parts to fix your TV.
6/11/2017 1:03:58 AM •
Samsung...
Answered
on Jun 11, 2017
Can i repair a broken screen on a lcd tv?
LCD stands for Liquid Crystal Display. It is all one unit and when broken can not be repaired. The only way to fix it would be to purchase a replacement screen but that would probably cost more than replacing the whole TV. You might look for a used TV of the same model with a good screen and a bad circuit board and exchange parts but it is far easier to replace circuit boards than LCD screens so if you find a similiar model with a bad circuit board take the good board from your set to make the one with the good screen work again.
8/2/2011 7:46:49 PM •
Samsung...
Answered
on Aug 02, 2011
I have a samsung lns4095d and it has short
Hi, Make sure that you don't have any florescent tube lights near your TV. The light has some affect on TVs. Move the TV away form light.
Do you have anything connected to the tv other than cable. If problem persist call repairman and see what he has to say. Good luck.
7/20/2011 6:25:21 AM •
Samsung...
Answered
on Jul 20, 2011
On all inputs, there are white dots or horizontal
The most likely problem here is the main board; there are a few surface mounted chips there which overheat and effects are very much like you describe.
For good or bad the same visual effect can be seen by a problem in the T-Con board , which is at the back of the LCD and is sometimes called LCD controller.
I don't think there's an easy way to tell the two apart.
Uploading a picture may help someone identify a problem they've already seen, but especially if it's a main board bad soldering / overheating then it may have many different forms.
There are about 100 contacts in quarter square inch under an IC and any two of them may start having short under.
1/16/2010 4:45:20 AM •
Samsung...
Answered
on Jan 16, 2010
CAN A VIDEO FROM YOUTUBE BE COPIED INTO A CD?
1.download Nero red andSpeedBit Video Downloader – Free Video Grabber from http://www.speedbit.com/video/
1.Play your favorite YouTube video or other web video in your browser.
2.Click the flashing Download video button.
3.Click Save, and the video downloads to your computer.
4.After you download a video with SpeedBit Video Downloader, click the Play button to watch the video.
5. put in a CD into the CD-rom
6.start Nero red go into favourites click make video CD
7.select the files to be burnt onto the CD
(The first time you click the Play button, SpeedBit Video Downloader checks to see if you have a compatible video player. If no player is detected, it will give you the option to download the free and popular VLC media player.
Click OK, and the VLC player starts downloading immediately.
You can also use any other player that supports FLV videos.)
10/4/2009 8:25:55 AM •
Samsung...
Answered
on Oct 04, 2009
