20 Most Recent Datamax DMX-I-4212 Label Printer Questions & Answers
Hold in the Feed button for 4-5 seconds, which causes the printer to attempt to "Auto-calibrate." If that doesn't solve it, then slide out the Media Sensor (green plastic bar that sticks out over the labels) about 1 inch from all the way in ("in" = left if looking from front). Then press Feed to clear errors. If still get same error, then look for piece of label or ribbon stuck in that error - ok to blow out with canned air. Then try holding in Feed again for 4-5 seconds to Auto-calibrate again.
Datamax... | Answered on Apr 29, 2014
Hold in the Feed button for 4-5 seconds, which causes the printericon1.png to attempt to "Auto-calibrate." If that doesn't solve it, then slide out the Media Sensor (green plastic bar that sticks out over the labels) about 1 inch from all the way in ("in" = left if looking from front). Then press Feed to clear errors. If still get same error, then look for piece of label or ribbon stuck in that error - ok to blow out with canned air. Then try holding in Feed again for 4-5 seconds to Auto-calibrate again.
Slide out the Media Sensor (green plastic bar that sticks out over the labels) about 1 inch from all the way in ("in" = left if looking from front). Then press Feed to clear errors. If still get same error, then look for piece of label or ribbon stuck in that error - ok to blow out with canned air.
Welcome to FixYa.
It shows that the printer is not communicating properly with the computer.
Solution:Uninstall the current printer driver from the control panel then re-install it.Your printer should came with a cd (software/driver/installer), use it to re-install the driver.
Thak you for using FixYa.
Datamax... | Answered on Dec 27, 2011
Try doing a recalibrate (menu sytem - follow on screen instructions)
Datamax... | Answered on May 25, 2011
Follow the arrow symbols stamped on the ribbon spool assy
It's a thermal printer, the printer therefore needs to get hot to heat the paper and in turn print the document. The paper changes form due to heat.
Check that your printer is getting hot. Also try a newer roll of paper.
If the paper feeds through and it gets cut off, then the heater needs to be repaired/replaced.
Claim warranty support if you can.
Take care!
damnor01
Datamax... | Answered on May 19, 2011
Looks like around $210
http://www.officelink-inc.com/ProductDetails.asp?ProductCode=OLK20218101&Click=90
Datamax... | Answered on Mar 14, 2011
Datamax DMX-I-4212 Label Printer Logo
55 questions posted
Top Datamax Office Equipment & Supplies Experts
rongg
Joseph Mueller
Joseph Mueller
Pierre Legault
Are you a Datamax Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
I Datamax
  • I Datamax
Most Popular Question
keep getting check supply error
  • Office Equipment & Supplies
