20 Most Recent Vizio GV47LF Television Questions & Answers
I had this exact problem on my Vizio 47" HDTV. I removed the speakers and all the screws on the back cover. Took the cover off and located the fuses on the largest circuit board. The are in the upper right hand corner of the board. There are 3 of them in a row labeled LF 1.5, LF 3.0 and LF 3.0. The are white in color with copper ends. I took a volt meter and measured continuity across all fuses individually and found the LF 1.5 to be blown. The guy at the electronics store sold me a barrel 1.5A fuse and told me to soldier it across the top of the blown fuse. It took an extra set of hands but the TV works perfectly.
Vizio GV47LF... | Answered on Jul 07, 2016
Hi Anon,
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
If your TV, flatscreen, or monitor is more than 5 years old it is more like to have suffered a component failure.
Take it to a repair shop.
https://www.youtube.com/watch?v=TR2iWN6b-LY
LCD TV Repair No Power Power Supply Common Symptoms Solutions How to...
Vizio GV47LF... | Answered on May 24, 2015
Chromecase is a USB 'stick' type device with a USB interface. The RGB port is a video only port on the TV and not compatible with USB signal levels or the physical plug type.
Vizio GV47LF... | Answered on Jan 08, 2015
Back-light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Vizio GV47LF... | Answered on Aug 20, 2014
Check the remote control for its infrared emission. Check it with fresh batteries. If you wish to get more details about how to check a remote control, please visit this site. One among the posts has details about it. Surf the site in "Mosaic" or "Magazine" view. It will make surf easier.
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" or "Magazine" view. It will make surf easier.
http://electrohelponline.blogspot.com/
Vizio GV47LF... | Answered on Jul 19, 2014
Check the power supply for Bad caps. unless you have dropped or slammed the LCD
Vizio GV47LF... | Answered on May 07, 2014
There is no back-light. This is the fault. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience.
http://electronicshelponline.blogspot.com/ Pull up older posts there.
Vizio GV47LF... | Answered on Mar 26, 2014
I had a similar problem a while ago! I checked up some threads around the web and it was when i found out a tip about replacing the inverter board pannels of the backlight!! guess what ? It worked for me... My Vizio HDTV is about 5 years old so far and it is up and running like a champ...!! I hope it works for you!
Vizio GV47LF... | Answered on Nov 25, 2013
The ABL circuit to main logic board should be checked. It is a skilled work. In most cased, this board might need replacement. Products powered by electricity should be serviced or repaired only by experienced professional technicians. Any attempt to service or repair the product by anyone else could result in serious injury or death. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock. Instead, contact the nearest service centre.
Vizio GV47LF... | Answered on Jun 05, 2013
Vizio GV47LF Television Logo
165 questions posted
Top Vizio Televison & Video Experts
Tony Nguyen
Tony Nguyen
Jerry Greenberg
Jerry Greenberg
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Vizio Televison & Video
Most Popular Question
vizio tv like add chromecast streaming
  • Televison & Video
