20 Most Recent
Funai MWC24T5 24 in. OLED Television Questions & Answers
Funai LCD TV NLC2704
THE SYMPTOMS YOU DESCRIBE ALMOST ALWAYS INDICATE A BAD MAINBOARD. (AKA THE GREEN BOARD INSIDE) AND RESULTING FROM FUNAI WALMART LOW GRADE COMPONENTS NOT BUILT TO LAST AND IN THIS CASE THE MAIN BOARD IS GOING BAD AND ITS ALMOST IMPOSSIBLE TO GET THE CORRECT REPLACEMENT BOARD THANKS TO WALMART AND FUNAI.
It won't turn on
sounds like a bad power transformer it will have to be serviced
My TV set won't turn on at all
First thing check the plug fuse is not blown,also some times the switch sticks when you push botton does it click if not a new one will need to be got, if switch is ok then you or some one will need to open the back in side were the mains cable goes in you should see a small fuse this shuld be re placed with another anouther one with same size fuse.i hope does the trick all the best Alan
Closed captioning
I had the same problem. My DVD player was connected to my HD TV via a HDMI cable as was recommended by the DVD owner's manual. I removed the HDMI cable and attached the three video component cables. Bingo, closed caption crossed immediately.
Funai dvd recorder e3 error
THat means it is unable to record successfully.
Try cleaning the lens with compressed air in a tin, (used for cleaning).
Do Not use a cleaning disc, as that can lead to permanent damage to the lens and focus coils.
How to reset my funai TV resolution mismatch
On your remote control, press MENU.
Highlight Settings with the down arrow button, then push OK.
Press OK after highlighting Television with the down arrow button.
Select TV resolution, then click OK.
Select HD 720p, HD 1080i, or HD 1080p using the arrow buttons.
Click OK.
FUNAI
What's the question?
