20 Most Recent
JVC LT-42E478 42 in. LCD Television Questions & Answers
Black screen in jvc lt 42e478
If you can see a dim image when you look at the screen at a sharp angle then you most likely have a faulty inverter board or faulty CCFL lamp/s.Most likely faulty inverter board which supplies high voltage to the CCFL lamp/s.
Picture does not show, but
First of all, look over the remote and see if there is a "sound only" button, or something to that effect. I know my Sharp TV has that. If not, try unplugging it for a bit then plugging it back in. Otherwise hopefully you're still under warranty. That's all I can think of.
I have a 42 inch
Radio speakers maybe too loud to cause contact resistance to the LCD connector in the circuit. Contact resistance can go as high as 40,000 ohms up from 0.1 ohm. Disconnect and reconnect may reduce contact resistance back to 0.1 ohm.
Original remote lost. have universal remote. cannot program TV
On the right hand side of this television there are panel buttons. It appears that your son in law knocked the tv out of the correct input. Press the input button in order to cycle through the 5 inputs. Typically pressing the input button on the side panel of a television and pressing it again and again and again will make it change inputs. Universally the buttons on the tv panel function as follows: Channel up moves the cursor up. Channel down moves the cursor down. Volume + moves the cursor right. Volume - moves the cursor left.
Hope this helps
My flatscreen tv is distorted
Speakers can cause problems with the correct display of video on TVs but usuall it only concerns direct view tv. Projectors should not have any problems or flat screens. I think you have a different problem Explain better what you mean by distortion in the JVC. Let me know and I will try to help you.
hardrocko
My jvc 42 inches tv stop working. it appears on
Hi.
Check cables connection at the back.
If there is not or weak signal it depends either on cable or on devices connected (receiver, DVD etc.).
Try browsing sources using the Input/source button. Try swapping cables.
If you are using the internal TV tuner, then the antenna cable is usually the problem.
Work on cables and connections and let us know how it goes.
Regards.
When i hook up my hdmi cable box how do i get my
HDMI is audio and Video in the one cable, if your stereo has HDMI in and out you can run it from your box into your stereo then into your TV, but only if everything is supported by your componets, I would suggest, HDMI into your TV, then from your box, stereo or optical into your stereo, by just using RCA cables. ALSO remember with audio compontes, more is MORE, more cable better quality (not length but size)
My JVC 58in. Flat screen blinks?
The cable connections for your TV are not connected properly or are loose or the cables might have damage or the connection ports are broken.
