20 Most Recent
Intermec EasyCoder PC4 Label Printer Questions & Answers
Wont print label correctly
Go into your printer preferences and check your default label size.
It must match the label size you are printing to. This must be done for each user of the computer.
6/21/2014 3:19:43 PM •
Intermec...
Answered
on Jun 21, 2014
When i open the printer
Try resetting the printer.How to reset the printer. Turn off the printer,
(in the back) then turn on the printer while holding down the Reset button on
the top. Release the reset button when the light turns green then wait for the
printing to stop. IMPORTANT: Next press the reset button for 1/2 second. If you hold it too long it will not reset the
printer properly.
11/1/2013 5:15:07 PM •
Intermec...
Answered
on Nov 01, 2013
My problem is i am
Read these instructions. You will need to buy a usb printer cable and follow these directions below. Good luck!We at our laboratory have about 35 Intermec printers and after much trial and error they work well for us. They practically never break. I have also called their tech support and they were very helpful. They advice was FREE. (I promise I do not work for them)Intermec Install Notes: (from Intermec)How do I install the USB driver for my EasyCoder PC4 (PC4B or PC4C) printer?AnswerTools Required:1. EasyCoder PC4 (PC4B or PC4C) printer.2. Microsoft Windows compatible PC. (XP/2000 recommended, Vista NOT supported ( Note from Dole: it works with Windows 7 and probably Vista and Windows 8)3. USB Cable.4. Available USB port on your PC.5. Latest version of the USB drivers (2.0 or better) which can be downloaded from http://home.intermec.com/eprise/main/GSS/Service/Content/Downloads/Show_DownloadSearchResults?Product=PRTRPC4CNote: There are two parts to installing the USB driver. You will go through the Found New Hardware wizard two times. The first part is installing USB port and the second part is installing the USB to Serial port.1. Download and unzip the USB drivers to a location on your PC.2. With the printer turned off plug in one end of the USB cable to USB port on the printer and the other end in to an available USB port on your PC.3. Turn the printer On.4. Now you will get prompted with the "Found New Hardware" dialog box. Select "Install from list or specific location" and click Next.5. Click Browse and select the location where you unzipped the files in step 1 and click OK.6. Click Next. The USB driver will now install.7. Now you will get another "Found New Hardware" dialog box for the USB Serial port. Select "Install from list or specific location" and click Next.8. Click Browse and select the location where you unzipped the files in step #1 and click OK.9. Click Next. The USB Serial driver will now install.10. Now reboot your PC. The newly installed port may not show available until you reboot your PC one time.The USB port is now successfully installed. In Windows the USB port will be assigned to a Com port. To find out what Com port number is assigned to it go to Device Manager and then Select Ports. You will see USB Serial Port (COMx). In addition, when using the Intermec InterDriver Windows print driver. The USB port will be shown as USB00x and the Description will be Virtual printer port for USB.(You may need to set the printer as the default printer)Other things to know about these printers: ( not from Intermec )1) There are 2 types Direct and Thermal transfer. Direct I think heats up the label to get the writing on the ribbon. Thermal transfer uses a one time use ribbon to transfer images to the label.2) You should use Intermec labels, if you otherwise the labels will probably not print properly3) How to reset the printer. Turn off the printer, (in the back) then turn on the printer while holding down the Reset button on the top. Release the reset button when the light turns green then wait for the printing to stop. IMPORTANT: Next press the reset button for 1/2 second. If you hold it too long it will not reset the printer properly.4) Every user will need to set the default label size.5) If the print is coming out is hard to read do the following. Open the printer then remove the ribbon if there is one and scrape the metal with your fingernail. They give you alcohol and a cotton pad but your fingernail will work fine. 6) Another problem we have sometime is a label falls off and covers a sensor so the labels do not know when to stop. This hardly ever happens but look under the labels and check the sensor.
11/1/2013 5:14:24 PM •
Intermec...
Answered
on Nov 01, 2013
I need intallation guide of
11/1/2013 5:10:17 PM •
Intermec...
Answered
on Nov 01, 2013
Label height is not managed
Go to printer properties and put in the custom label size. You will need to do this for each user of the computer.
11/1/2013 5:08:27 PM •
Intermec...
Answered
on Nov 01, 2013
What causes the printer to stall after changing label roll or ribbon.
Try resetting the printer:Turn off the printer, (in the back) then turn on the
IMPORTANT: Next press the reset button for 1/2 a second. If you hold it too long it will not reset the
printer properly.
11/1/2013 5:03:44 PM •
Intermec...
Answered
on Nov 01, 2013
