20 Most Recent
ASUS CROSSHAIR Motherboard Questions & Answers
How do I get USA warranty support from Asus?
This is the direct link to the Asus RMA request form for USA & Canada.
http://vip.asus.com/eservice/usa_rmaserv.aspx
This is the link to the technical support request form.
http://vip.asus.com/eservice/techserv.aspx
Robert from Blitware
My mobo is not booting no post
Test your PSU or replace it if your power supply units fan
is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or
to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including
electrical extensions,IDE,SATA
the leads from your
"((MOTHERBOARD TO THE HARD DRIVE))" make sure they have a secure connection and
are not faulty or just replace them they could be faulty
make sure all leads that
are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections
and are not faulty even the electrical extensions or just replace them they could
be faulty a computer
needs its connections to continue its cycle and have an end so any faulty leads
will end up with a computer error hope this helps
Computer keeps crashing through crossfire
It is possiable that your PSU is not powerful enough to support the cards; or one is faulty. Try checking the specifications of the card, and get a PSU that is rater greater by a few hundred watts at least. If that is not the cae; check the bios to make sure that crossfire is enabled.
Sometimes it turn on but it doesnt boot at all
CPU init is CPU initialisation as you guessed. It should pass extremely quickly however, I'm talking under a second.
The fact that it isn't, or is only passing sometimes, indicates a CPU or Motherboard fault.
Make sure you have the 4 or 8 pin cpu power connector properly plugged into the motherboard.
Installed Crosshair MB in new case. Motherboard
Make sure that the motherboard LED switch on the back panel is set to off and if want to turn
it on go into bios and set it. If it is active thru switch and not thru motherboard bios it will not allow you to turn on PC cause it is in maintenance mode.
Make sure that the switch to turn on mb LED is off and if want to turn it on go into bios and set it. If it is active thru switch and not thru MB it will not allow you to turn on PC cause it is in maintenance mode.
Post
hi i also have a crosshair mobo and it will not post or start up if the internal blue led's are on switch them off on the back and i'm sure it will start
Fan mount broken
YEs you can purchase new processor fan and also if you are some tech savvy then you can change its clip.
BUt new processor fan purchase is good choice becasue not cost of it.
ASUS Crosshair won't boot
some motherboard have 2 power supply plugs 1 for board 1 for cpu check and see if yours is like this 1 is a wide one with about 15/20 pins in the other is asmall square one with 4 pins
I swithed to asus crosshair
HAVE YOU CHECKED TO SEE IF MOTHERBOARD SUPPORTS THAT EXACT CPU.OR YOU MAY NEED TO CHANGE A SETTING(S) IN THE BIOS.TRY NOT USING AUTO DETECT FOR CPU MANUALLY ENTER INFO.RICHARDM69
Procesor speed
Well, I would start by going to the ASUS web page and look up your specific motherboard. Here is the link right to the board---
http://usa.asus.com/products.aspx?l1=3&l2=117&l3=0&l4=0&model=1283&modelmenu=2
the specs listed at ASUS's site don't say specifically"how many Gz processor can my mothereboard suport" although they will point you in the right direction. Open up the site on a seperate internet page if you haven't already and look at if for me. Do you notice where it mentions the Socket types that it supports in the CPU section?? Basically the page is telling you what type of processors it will run. I believe the Athlon 64 x2 is the fastest out of what they have listed, although i did not look up the specs. You should be safe buying any speed Athlon 64 x2, Athlon 64 FX, Athlon 64 or Sempron processor. Hope that this was helpful, if it was could you please give me a good review? Thanks.
