20 Most Recent Toshiba Portege M200 Tablet PC Questions & Answers
Portege M200 Tablet PC: my tablet pen stopped working, what can I do?...
My tablet pen stopped working what can I do?
4/8/2018 8:35:15 PM • Toshiba Portege... • Answered on Apr 08, 2018
2answers
Gateway/MPC e295c tablet powers off without warning
I am also having the same issues with my E-295c tablet as well. Were you able to figure out what your problem is? I thought mine may have been my port replicator, but it continues after removing that. And mine always seems to do it for sure everytime I have a full screen video playing. Thanks!
10/29/2014 6:35:18 AM • Toshiba Portege... • Answered on Oct 29, 2014
3answers
Will a Bamboo Pen work on a Toshiba tablet pc M200
^The question is NOT asking about a USB thumb drive, and a lot of people seem to have failed to understand this.
This is a comprehensive forum thread regarding digitizers that work with Penenabled Tablet PCs: http://forum.tabletpcreview.com/showthread.php?t=12695
I don't believe Bamboo pens work.
2/13/2013 8:17:41 AM • Toshiba Portege... • Answered on Feb 13, 2013
2answers
I'm trying to get into
Click HERE for an instructive website on the M200.
hold the ESC button down during boot to enter bios.
12/13/2012 6:09:46 AM • Toshiba Portege... • Answered on Dec 13, 2012
Windows won't start
this problem occurs when the files in the master boot record get corrupt due to the actions of the viruses or any malfunction
this problem can be solved by repairing the current OS by the OS cd if you are an expert you can edit the MBR probably the message show NTLDR missing ,right
or format the system will surely solve the problem
thanx PLZ vote
10/4/2012 8:15:32 AM • Toshiba Portege... • Answered on Oct 04, 2012
Battery charges but even if its 100% and i remove the charger it will tll battery low
Problem is is the battery already. Try to borrow or sample another battery of the kind then figure out if you need to buy one or if it's still in waranty.
9/30/2012 7:33:00 AM • Toshiba Portege... • Answered on Sep 30, 2012
I forgot my admin password on windows xp
That's nothing serious, many methods for you to reset windows xp admin password.You can use safe mode, or adopt Windows Password Reset, and you also can use reset disk if you have created before.
4/9/2012 2:36:10 AM • Toshiba Portege... • Answered on Apr 09, 2012
2answers
I am looking for the Toshiba Portege M200 Tablet
What part of it do you need help with?
2/7/2012 5:06:48 AM • Toshiba Portege... • Answered on Feb 07, 2012
I want to know how
This is in case you cannot boot into windows but you can get into bios: Open your disk drive. Insert windows operating system disk into your disk drive. Restart your computer. If you can get to the stage where you can see see bios entry key then keep pressing whatever key it is that you press to get into bios at start up. Select the option that let's you choose the drive to boot from, mine is in advanced bios options. then go to either something like bios features or change boot drive.select whatever drive represents your CD-ROM drive and select it to be the first boot drive. then save exit bios, I do this by pressing escape then Y to save and boot from the rom drive. This will let you restart your installation of windows and re-format the drive... If you can boot into windows: Then either re-format the drive and delete the partition when you do or... Run a recovery of the system by installing your disk and letting it get to the stage wher it asks what action/task you want to perform and press r when prompted then follow the prompts to repair the files. This might not work though, you could even try running a disk check as maybe a lucky chance of repair if you can get into windows. If your PC keeps trying to boot from the CD drive after repair then re-enter bios at start up and change your hard drive back to first boot device to boot into windows. It's better if you re-format though as repairing windows can be a little tricky.
11/8/2011 10:14:12 AM • Toshiba Portege... • Answered on Nov 08, 2011
Ide #0 error on boot
It typically means the hard drive has died
11/8/2011 10:08:33 AM • Toshiba Portege... • Answered on Nov 08, 2011
My toshiba portege m200 will
If that is you only concern, just set the time using the clock applet from inside Windows. Make sure to synchronize with the Internet time servers.
8/19/2011 2:06:46 AM • Toshiba Portege... • Answered on Aug 19, 2011
My Toshiba Portege M200 just
Try removing the battery and see if it will boot without it
Then check the caharger, charging light should be green and steady on the charger itself
If it is flickering, it meand power is not making a circuit, test charger jack with a DC volt multimeter with one probe to the outer side (earth) and one on the inner (positive). If this is ok, check the charging socket is not loose (if it is, will need replacing).
After that, suspect the power strip or charging / powerboard is dead on the motherboard
3/23/2011 12:18:53 AM • Toshiba Portege... • Answered on Mar 23, 2011
I ave a toshiba m200
Hi,it is possible that the resultant cause the problem is your hard drive(caused by the hard disk failing to be READ from or be WRITTEN to,in this case be READ from),or one of your Memory modules is failing,so first of all try swapping or switching the RAM modules from one slot to the next,one at a time,if system is still slow,take out your hard disk,get a converter,slave hard disk to another system copy your files out and get a new Hard disk.
1/4/2011 11:20:42 PM • Toshiba Portege... • Answered on Jan 04, 2011
0answers
Clear cmos toshiba m200
In case nothing worked to reset BIOS password (taking battery out, reseting jumper J1) you can use thrid party software from Hiren's Boot CD to reset the password. You've got Kill CMOS on there, for example which wipes out CMOS. Here's the download link to the entire CD: http://www.hirensbootcd.org/download/Hirens.BootCD.12.0.zip
11/29/2010 10:00:31 AM • Toshiba Portege... • Answered on Nov 29, 2010
Toshiba Portege M200 Tablet PC Logo
68 questions posted
Top Toshiba Tablets & eReaders Experts
k24674
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a Toshiba Tablet and eReader Expert? Answer questions, earn points and help others
View Most Popular
Portege Toshiba
  • Portege Toshiba
Most Popular Question
toshiba portege m200 just
  • Tablets & eReaders
