20 Most Recent
MSI K9MM-V Motherboard Questions & Answers
I have a ms 7312
Hello, I've pasted the below from the MSI website for the board:
Main
Memory •
Supports Dual DDR2 533/667/800
- 2 DDR2 DIMMs (240pin / 1.8V)
Supports a maximum memory size up to 2GB.
regards,
Nicam49
p.s. don't forget XP supports 2gb max anyway.
Ms 7312 ver 1
http://www.cnet.com/products/msi-k9mm-v-motherboard-micro-atx-socket-am2-k8m800-series/specs/
MSI K9MM-V - motherboard - micro ATX - Socket AM2 - K8M800
Part Number: 7312-010R
1 Related Model
GENERAL
Packaged Quantity
- Chipset Type
VIA K8M800 / VIA VT8237R Plus
- Max Bus Speed
800 MHz
- Processor Socket
Socket AM2
- Max Processors Qty
- Compatible Processors
Athlon 64, Sempron, Athlon 64 FX, Athlon 64 X2
- Manufacturer
MSI Computer Corp.
SUPPORTED RAM
- Max Size
2 GB
- Technology
DDR2 SDRAM
- Bus Clock
800 MHz
- Speed
PC2-6400
- Features
dual channel memory architecture
GRAPHICS
- Graphics Controller
VIA UniChrome Pro
- Memory Allocation Technology
shared video memory (UMA)
AUDIO
- Type
6-channel
- Audio Codec
Realtek ALC655
- Compliant Standards
AC '97
LAN
- Network Controller
Realtek RTL8201CL
- Network Interfaces
Ethernet
EXPANSION / CONNECTIVITY
- Storage Interfaces
ATA-133 - connector(s): 1 x 40pin IDC - 2 device(s)
SATA-150 - connector(s): 2 x 7pin Serial ATA - 2 device(s) - RAID 0 / RAID 1
- Internal Interfaces
1 x floppy
- Additional Connectors (Optional)
4 x Hi-Speed USB
FEATURES
- BIOS Features
ACPI support
MISCELLANEOUS
- Software Included
drivers & utilities
- Width
8.1 in
- Depth
9.6 in
- Package Type
retail
GENERAL
- Manufacturer
MSI Computer Corp.
HOPE THAT HELPS
7312 manual
Hello download the manual here:
MSI Global Motherboard K9MM
Check power supply, the ram modules. This is a AM2 socket, check for the cpu is properly inserted in the socket and the lever is closed.
When it stops any bsod ??
Check also for bad caps.
Good luck
