20 Most Recent Compaq tc4400 Tablet PC (RL875AW#ABA) Questions & Answers
0answers
Mera laptop ki sound nahi
check if mute is active, if so remove mute.
else to download drivers for your operating system click here
8/10/2011 9:54:30 AM • Compaq tc4400... • Answered on Aug 10, 2011
How can I ad an additional stick of RAM (2 GB) on
There should be a cover behind the laptop, unscrew these tiny screws and the back cover should open. Then you want to located where the rams are at. In some case the ram slot is already being used by the original rams and you need to take these out to install the new ram. Before hand, make sure your laptop support the correct type of the ram, in your case it will support ddr2 sdram up to 4gb. So pretty much once you locate the ram slot after opening the back panel... then just install it.
1/14/2011 2:47:04 AM • Compaq tc4400... • Answered on Jan 14, 2011
Forgot password, does not have cd rom drive, need
How to obtain Vista Recovery Media and/or use the Vista Recovery Partition on your computer to put it back to Factory Settings.
There is no legal free Vista download available.
Contact your Computer Manufacturer and ask them to send you a set of Vista Recovery disk/s.
They normally do that for a small $ cost.
Also, ask them if you have a Recovery Partition on your Computer/Laptop to restore it to Factory settings.
See if a Manual came with the computer, or go to the Manufacturer's website, email or phone them for info on how to do a Recovery.
Normally, you would press F10 or F11 at Startup to commence the Recovery Process..
Another way I have seen on some models is to tap F8, and go to a list of Startup options, and start a Factory Standards Recovery from in there, by selecting the Repair computer option.
Also ask them if it is possible to make Recovery Disk/s from the Recovery Partition in case of Hard Drive failure or System Crash.
They will tell you how to do that.
Each Computer Manufacturer has their own way of making Recovery Disk/s.
Or borrow a proper Microsoft Vista DVD(not Dell, HP, etc).
A proper Vista DVD contains all Vista versions.
The Product Key determines which Vista version gets installed.
There are 2 Vista disks: one for 32bit Operating System, and one for 64bit Operating System.
If a clean install is required with a proper Vista DVD (not HP, Dell Recovery Disks):
Go into your Bios/Setup, or Boot Menu, at startup, and change the Boot Order to make the DVD/CD drive 1st in the Boot Order, then reboot with the disk in the Drive.
At startup/power on you should see at the bottom of the screen either F2 or DELETE, to go into Bios/Setup, or F12 for the Boot Menu
http://support.microsoft.com/default.aspx/kb/918884
MS advice on doing clean install.
http://www.theeldergeekvista.com/vista_clean_installation.htm
A Tutorial on doing a clean install
http://www.winsupersite.com/showcase/winvista_install_03.asp
Windows Vista Installation Super Guide
After installation > Go to your Laptop/Computer Manufacturer's website > Drivers and Downloads Section > Key in your Model number > Look for latest Vista Drivers for it > Download/install them.
Save all Data, as it will be lost during a clean install.
Post back if it is not working we will be happy to help you.
Hope this helps.
Cheers!!!!
1/9/2011 6:31:21 PM • Compaq tc4400... • Answered on Jan 09, 2011
Sir i have reinstalled windows
You need to go to the Tablet manufacturers website and download and install the correct driver, I think that should sort out your problem.
If this doesn't sort it out, then perhaps you have a faulty pen? However my guess is it's just a driver issue.
8/20/2010 5:36:57 AM • Compaq tc4400... • Answered on Aug 20, 2010
Compaq tablet tc4400 screen does not rotate
Contact HP for a new Hinge Assembly.
4/14/2010 1:24:59 AM • Compaq tc4400... • Answered on Apr 14, 2010
How can I turn off the keyboards
at first go to my computer..then in the meny option (where file , edit, view, toll is located), click the tools button and click on folder option. a dialogue box will appear then. in the dialogue box, go to the general tab and point to the 3rd option "click items as follows" and then select single click to open a file..
thank you
don't forget to give feedback and ratings
2/4/2010 3:07:57 PM • Compaq tc4400... • Answered on Feb 04, 2010
I have installed linux umbutu and it removed my
you will need to live boot off the ubuntu cd and do a low level format of your hard drive. you can use gpart to do it
11/18/2009 8:50:01 PM • Compaq tc4400... • Answered on Nov 18, 2009
2answers
Cannot Load Windows/Windows Setup Does Not Detect Hardrive
Harddrive is most likely bad get another and install windiws... if you found the right place they could "ghost" your information onto the new one!
9/26/2009 10:00:00 PM • Compaq tc4400... • Answered on Sep 26, 2009
TC 4400
The THERMAL PASTE which bonds your laptop's heatsink and cpu together is not good. It will not obsorb the heat good enough, which causes your laptop to OVERHEAT from time to time... Have someone re-apply a new thermal paste on it then it will be fine...
- I've worked on laptops and desktops for 10+ years. Take my words for it.
9/26/2009 9:48:14 PM • Compaq tc4400... • Answered on Sep 26, 2009
Startup problem
If you are getting a Blue screen repeatedly and you can't start up to windows in any custom setting ( from f8 start up menu ) one way to solve the problem is to Use the restore disc or windows installation cd or dvd to install windows into the computer or perform a repair installation if a windows already exists on the computer and the setup can find it.
how to perform a repair installation
this is for xp, but its similar on 2000 and on vista.
insert your Windows XP Setup CD, and restart your computer.
1.When the Press any key to boot from CD message is displayed on your screen, press a key to start your computer from the Windows XP CD.
if not then the computer is not set to start up from a cd, you can either enter the setup / bios to change that setting OR right when you power up the computer look at the screen it will say what button to press in order to enter boot menu or bios, it will very likely be button F12 or similar, it should say on the screen when you power on.
if it doesn't, then you need to go into the bios and change the boot order so that the computer starts from the CD first.
after that you should be able to start from the cd and install the OS (Operating system, eg.Windows)
here's some info on how to work the bios: http://www.whitecanyon.com/how-to-change-boot-order.php
Repeat step 1 when you have changed the boot order.
2.Press ENTER when you see the message To setup Windows XP now, and then press ENTER displayed on the Welcome to Setup screen.
3.Do not choose the option to press R to use the Recovery Console.
4.In the Windows XP Licensing Agreement, press F8 to agree to the license agreement.
5.Make sure that your current installation of Windows XP is selected in the box, and then press R to repair Windows XP.
6.Follow the instructions on the screen to complete Setup.
7.Ones windows is working you will need the drivers for your computer, they are at the makers website, for hp and compaq. www.hp.com for acer http://support.acer-euro.com/drivers/downloads.html for all other brands go to google and write Brand drivers. Should get you to the right place. Dell is most likely www.dell.com and so on.
6/3/2009 10:11:53 AM • Compaq tc4400... • Answered on Jun 03, 2009
Compaq tc 4400 battery does not charge
You may need a new battery... Somehow the way to test this is to try charging it on another laptop of the same model.
1/8/2009 4:57:52 AM • Compaq tc4400... • Answered on Jan 08, 2009
Blank screen on boot
hi firend
u havre to do this chk the ram remove & clean it reinstall it in your pc if problem occers then
u have heting problem ur prosser fan has been dust so remove your prosser fan clan it put it back agin
1/3/2009 1:15:32 PM • Compaq tc4400... • Answered on Jan 03, 2009
Hi i need driver o software pen ( compaq tc 4400 XP )
I belive you will find what you are looking for on this page please follow this link to download your touchpad/PEN driver >
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=1849071&prodTypeId=321957&prodSeriesId=1847962&swLang=8&taskId=135&swEnvOID=1059#11318
just copy that link and paste it into your address bar at the top of your internet browser then hit search or press enter.
hope this helped you but if it does not help please do not hesitate to re post your issue and we will keep trying to solve it for you.
Thanks Reguards: PC Pro
12/16/2008 6:10:06 AM • Compaq tc4400... • Answered on Dec 16, 2008
Screen keeps flipping around
Re-install the software used to flip screen...
12/15/2008 12:54:18 AM • Compaq tc4400... • Answered on Dec 15, 2008
Problem: Cannot Load Windows/Windows Setup Does Not Detect Hardrive
My Hp Compaq tc4400 Does not load Windows and when i try to install a new one and error Message apears saying that it cannot detect any hardrive, but when i press F9 for boot selection Notebook Hardrive is dected and availble, i tried removing the hardrive and re-insert it also it dint work could somebody help plssss
4/28/2008 9:47:08 PM • Compaq tc4400... • Answered on Apr 28, 2008
Compaq CT101 Tablet. Looking for repair manual for it.
Unfortunately a Service Repair Manual doesn't appear to exist. Apart from replacing batteries, the rest is one motherboard and a screen. https://www.google.com/search?q=compaq+ct101+tablet+service+manual ..
5/6/2022 1:30:59 AM • Compaq Tablets &... • Answered on May 06, 2022
How do you fix a power- on password on a HP Compaq
power on password poblem
6/10/2011 10:47:01 AM • Compaq Tablets &... • Answered on Jun 10, 2011
Compaq tc4400 Tablet PC (RL875AW#ABA) Logo
26 questions posted
Top Compaq Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Compaq Tablet and eReader Expert? Answer questions, earn points and help others
View Most Popular
tc Compaq
  • tc Compaq
Most Popular Question
ad additional stick ram 2 gb
  • Tablets & eReaders
