20 Most Recent
Ricoh Aficio SP-C210SF Printer Questions & Answers
Need default admin password for
The default password is stated in the webinterface when you click on the red or green key
default admin username is "admin" and the password is "access"
sounds to me you are using the "wrong driver" double check the driver and the OS you are using.
I would also turn the printer off and clear all print jobs from the print que and restart. After loading the new driver do a test page from the driver.
Fuser replacement for my ricoh
Generally it is recommended to have a tech do this. the reason being that if you accidently touch the fuser wire the oil from fingers can fritx it. There is a counter to reset but all the playing around to do this ( with a warranty if it goes wrong) is better to have it done by the tech.
Please rate our help to keep the FREE service online ++++
Thank you for using FIXYA.COM
Part of printed copy is washed out ricoh aficio sp c210sf
Seems its fuser assembly fault.
Fuser assembly is a part to fix toner image permenentely with the help of hot rollers on media. The temparature varie depends on model, in case the temparature not reachess specified level you may get image fixation problem, the same what you are facing. Replace fuser assembly.
Continuous jam paper feed cl3500n
I THINK THE NUMBERS BUTTON HAD PROBLEM, TRY TO CHANGE THE NUMBERS BOARD & SEE IF THE PATTERN STILL PERSIST. IF THE PATTERN PERSIST ALTHOUGH YOU INSERTED NEW NUMBER BOARD, THEN YOU HAS TO GO IN SP MODE TO CHANGE PRINT SETTING
Paper jam c
Unable to print troubleshooting and routine maintanance chapter in user's guide
Ricoh aficio sp-1100 sf toner
WE HAVE RICOH PRINTER SP 1100SF & REPLACED CARTRIDGE WITH NEW RECYCLED BLACK TONNER CARTRIDGE FROM POWER POINT, BUT UNABLE TO PRINT AS CHIP GIVEN IS NOT ACCEPTED BY PRINTER. TRIED 3 DIFFERENT CHIPS STILL PROBLEM PERSISTS. WHAT MAY BE THE RESEASON AND SOLUTION
Ricoh SP C221n not printing test page
You can install the SOM (Smart Organizing Monitor), it is a utility which can check the status of a printer and set up a printerfrom a PC. This utility is executed from a printer driver.Start the SOM to see the status of your printer..
