Amana AKS3040... | Answered on Jan 19, 2015
Amana AKS3040... | Answered on Oct 02, 2014
Amana AKS3040... | Answered on Jun 11, 2014
Amana AKS3040... | Posted on Feb 17, 2014 | Be the first to answer
Amana AKS3040... | Posted on Feb 04, 2014 | Be the first to answer
Amana AKS3040... | Posted on Dec 28, 2013 | Be the first to answer
Amana Cooktops | Uploaded on Oct 24, 2013
Amana AKS3040... | Posted on Oct 27, 2011 | Be the first to answer
Amana AKS3040... | Posted on Oct 24, 2011 | Be the first to answer
Amana AKS3040... | Answered on Sep 27, 2011
Amana AKS3040... | Answered on Jun 08, 2011
Amana AKS3040... | Posted on Jun 07, 2011 | Be the first to answer
Amana AKS3040... | Posted on May 18, 2011 | Be the first to answer
Amana AKS3040... | Answered on Dec 21, 2010
The gas is delivering as you may already saw with gas manifold and pipes going to each burner. In every burner there is one orifice with a tiny hole. So you haven't mentioned what liquid but in any case we advice that you can disassemble first the manifold and clean it very well. You can use a small piece of water hose adapt it on one side and blow air in it and check if it coming from other end. Is the only way where it is cogged.
Here is the link with the parts of your stove.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5167493
Amana AKS3040... | Answered on Nov 02, 2010
From your description this problem is simple to understand and easy to fix. The wire harness has a loose contact from the sparking rod to the spark module. At either connection points the connection is loose so it sometimes make contact and sometimes not.
So you need to disassemble the unit by removing burner and the top unit so you will find the wires and spark module under top unit.
Here is the link with all above parts of your unit which will help you.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5167493&diagram_id=1320529#d1320529
Amana AKS3040... | Answered on Nov 01, 2010
Amana AKS3040... | Answered on Sep 10, 2010
Amana AKS3040... | Answered on Sep 05, 2010
Amana AKS3040... | Answered on Aug 19, 2010
49 questions posted
15 Questions
-2 Questions
3 Questions
5 Questions
