20 Most Recent
Microsoft ZUNE JS8BRPBDLUG MP3 Player Questions & Answers
How to download music on to it
follow the steps below:
- Put a CD of your favorite music into your computer, and then open your Zune player. Click on the music that you want to copy.
- Click on the "Rip" button, and then save your music with any of the
following file extensions: .wma, .wmv, .mp3, .jpg, .mp4, .m4v, .m4a,
.m4b or .mov. The ability to play music in all of these formats is one
of the features that make Zune such a superior digital player.
- Plug your Zune player into your computer using a USB cable, and then
the Zune software will automatically import all of your selected music
into the player. Set the "Sync" option to "Default" so that all the
music in your directory will install in your Zune player whenever you
plug it into your computer.
- Purchase music online by either buying each song individually (usually
for about 99 cents a song) or buying a membership to a website where
you get unlimited downloads. You automatically get a membership to Zune
Marketplace when you purchase Zune, and you can get unlimited downloads
there.
I hope the above steps will help to solve your problem.
Good luck
Used a Micromax Mobile Charger
Did the charger documentation say it was Zune compatible? If so, you might try contacting the charger's manufacturer, since it sounds like you fried your board.
Does your Zune respond at all if plugged into a computer via a Sync cable?
Laser c50 mp4
go to microsoft's site, or xbox.com and look for the Zune software. they still offer it. once installed you can add music to your Zune.
Download music to my zune?
You need to go to Microsoft's site and download the Zune software. Once that is installed you can add music to your Zune.
When I plug in my Zune to charge, it displays a
most likely the battery is old and isn't holding a charge anymore. this isn't a difficult problem to fix, but depending on your Zune model might require some simple soldering. replacement batteries can be found on eBay, and if you have a 1st Gen it is a simple swap. anything later and you will have to have basic soldering skills, or know someone who does. good luck!
Laser c50 mp3
When you connect the MP3 player to your
computer with the supplied USB cable then computer detects the player as an
external storage device or a Removable disk, you can then view the folder on
your MP3 player. Open the music folder and create a new folder on the player
exactly the same way you create a folder on your computer's hard drive. To
organise your music, make a folder name with the name of the music album and
place the album's MP3 files in this folder, then copy the mp3 files from the computer
into this folder.
You will then be able to select the music you want to play by the music album
folder.
To delete a file
from your MP3 player, connect the supplied USB cable to your player and then
plug it into the USB port of your computer.
The computer will detect your player then click on this device to view the
files, you can then click on the music file to highlight the file and then
press the Del key to delete the file off your MP3 player.
Check the specification of your MP3 player to determine the
type of video file format it uses.
Most common video files that MP3 players use are, AVI and
WMV, there may be others such as FLV, MOV and DivX.
If your player cannot play a video then it is an
incompatible video file format, then you need to convert that video file to a
format that your MP3 player uses. After video conversion then copy the video
files to your MP3 player using the USB cable from your computer.
Click on this link for instructions on converting video
files for MP3 players :-
http://www.fixya.com/support/r5874192-play_videos_mp3_player
MP3 players can only play music files in mp3 file format.
You can download mp3 music files from the Internet to
your computer and then copy them to your MP3 player using the USB cable.
For your CD collection, you need to convert your CDs to
mp3 music files onto your computer or download them from the Internet and then
copy them to your MP3 player after you have connected the USB cable to
the MP3 player and the computer.
You can do this using Windows Media player and Rip the CDs - Media Player will
create a MP3 music file for each music track.
Click on this link for instruction on converting music
files to mp3 file format :-
http://www.fixya.com/support/r5798418-creating_transferring_mp3_music_files
I need to download the
You shouldn't have to install the driver yourself! Uninstall and Delete all files connected to your Zune (except your music files!). Now, plug your Zune in, and the computer should locate/install all the necessary drivers and software needed to operate your Zune. Then, you can format/personalize the Zune software the way you want. The computer downloads the drivers for you! Try that! It should work wonderfully!
I want to delete our zune account
Hi pedrojohnsonTry this solution to your problem:Open your browser and go to Zune.net. Click the "Sign In" link at the top right corner on the page. Enter your user name and password on the sign-in page.Click the "Support" in the upper right corner of the page, then click the "Change Password" link on the right side of the page.Enter your Windows Live ID in the corresponding field and type the security code that appears. Click the "Continue" button.Click on "Close Account" at the bottom of the next page. Scroll down and type in your password in the field that is provided. Click on the "Yes" button. This will close both your Windows Live account and your Zune account.Please take time to rate meBud
Zune player
As a last resort or if you are receiving error code C00D2772, erase the
device, and then sync your content again. To do this, follow these
steps:
Start the Zune software on the computer.
- Connect your Zune device by using the Zune Sync Cable.
- Click Settings, and then click device.
- Click SYNC OPTIONS, and then click ERASE ALL CONTENT.
- When you receive the following message, click Yes:
Please Confirm. Are you sure you want to erase the contents of the connected Zune?
You receive the "Erase All Content" message. This may take several
minutes. Do not move or disconnect the Zune device until the message
disappears.
