20 Most Recent ASUS M2N-E SLI (M2N-E SLI GREEN) Motherboard Questions & Answers
For some reason the monitor
pls click the following link and do what they mentioned. and this is not the issue with the monitor and the issue of video driver from the PC. https://www.winhelp.us/low-resolution-video-vga-mode-in-windows.html
9/6/2017 6:05:55 AM • ASUS M2N-E SLI... • Answered on Sep 06, 2017
2answers
Why cant I get a CD Ripper to create a wav or mp3?
ok i really did't understand all of that mobo jumbo lol but if its a cd ripper programs u are looking for the u should check out this site www.download.com
3/23/2014 8:25:59 AM • ASUS M2N-E SLI... • Answered on Mar 23, 2014
2answers
Hello.i need a driver for
The page linked below has the drivers for Vista 32 bit, which should be compatible:
http://support.asus.com/Download.aspx?SLanguage=en&m=M2N-E+SLI&p=1&s=24
5/10/2013 3:05:35 PM • ASUS M2N-E SLI... • Answered on May 10, 2013
Ethernet drivers
Hello you can download the driver here at ASUS:http://www.asus.com/Motherboards/AMD_AM2/M2NE_SLI/#downloadPlease select your windows system 32 or 64 bitclick on the chipset driver and select global for download.Unzip the file before installationAnd uprade the other files alsoGood luck
10/31/2012 6:16:32 PM • ASUS M2N-E SLI... • Answered on Oct 31, 2012
2answers
My computer shutdown unexpectly
Test all power and data leads that attach to your hard drive IDE,SATA the leads from your MOTHERBOARD TO YOUR HARD DRIVE make sure they have secure dust free connections and are not faulty or just replace them they could be faulty motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail
make sure all leads that are attached to your drives dvd\cd floppy have secure dust free connections and are not faulty or just replace them they could be faulty a computer needs
power and data to travel through every working device and to continue its cycle and have an end so any faulty leads will end up with a computer error
even something as small as a faulty power lead or fan lead can cause you problems
computers need all of the data and electrical current to travel through every working device and to have an end to be able work properly
make sure ram modules and cmos batteries have dust free secure seatings and cmos battery has charge some motherboards cmos batteries are soldered in
you might not have enough computer ram
not having enough computer ram will run your computer over its limits putting to much strain on the CPU central processing unit and can cause memory dumps
you might have to many programs trying to or accessing the internet at the same time scroll to bottom toolbar (bottom of screen) right click select task manager applications you will see whats running if you see anything you dont need running select end now and you might uninstall that specific program if you or computer does not require it to run and some unnecessary programs that could be jamming up your computer also under processes see what is ticking over in the background again if you see something you dont need to be and users you will see who is using your computer you might need to add more computer ram if you're not sure if a module is right for your system use the Crucial Memory Advisor tool for a list of guaranteed compatible modules. first you will need to select the manufacturer from a drop down list then select your product line from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system you should always ask for a guarantee on the compatibility of the ram before making any purchase
might be getting hot
check you CPU make sure its securely seated and has thermal grease
http://www.hardwaresecrets.com/article/Thermal-Compound-Roundup-February-2012/1490
hope this helps
7/31/2012 7:54:46 AM • ASUS M2N-E SLI... • Answered on Jul 31, 2012
0answers
After instal windows7 the system hangs after
Restart your computer During the boot process you will see on the screen to press a certain key to enter setup Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart make sure your ram modules are seated properly with no dust in there sockets click start right click on computer select proprties you will see ammount of ram installed and usable ram also cmos battery is seurely seated with no dust in the socket on some motherboards cmos batteries are soldered in computers need power and data to travel through every working deviceand to have a finishing point to work scroll to bottom toolbar (bottom of screen) right click select task manager applications see whats running also applications if you see something running that should not click end now hope this helps you
9/26/2011 10:29:02 PM • ASUS M2N-E SLI... • Answered on Sep 26, 2011
Have a ASUS M2N-E and
try blowing out all of the dust from your keyboard using a fine air blower from an air compressor making VERY sure there is no MOISTURE in the lines. dust causes static which causes lots of problems with a computer and its parts or if this does not fix the problem Click start control panel keyboard you can change your settings there or you might have uninstall the keyboard then restart your computer then reinstall it and its drivers click start control panel keyboard hardware then properties you hould see driver details and have options to,update driver,roll back driver,uninstall click start control panel administrive tools computer management device manager scroll to keyboard you might see a yellow question mark ? right click update driver if your computer came with a motherboard disc the drivers could be on it diconnect the keyboard then reconnect it then reinstall the driver make sure the lead has a secure seating if applicable or the usb device test leads attached from motherboard to hard drive make sure connections are good and dust free you might have to many programs running at the same time try uninstalling a few unnecessary programs also scroll to the bottom of your screen toolbar right click select task manager applications & processes you will see what is running if you see something you dont need running select end now you might have a virus freezing/slowing your computer you might need to install more RAM click start right click on my computer select properties you will see all imformation about your computer including installed ram if you need more help with this post a reply hope this helps you
9/1/2011 11:51:09 PM • ASUS M2N-E SLI... • Answered on Sep 01, 2011
2answers
I have am2n-e sli mobo,
The one long-two short beep code is for bad memory, not for a failed video card.
Shut down your computer, remove one stick of ram, reboot the computer, and repeat for each stick of ram, until you find the bad stick.
7/26/2011 10:17:25 PM • ASUS M2N-E SLI... • Answered on Jul 26, 2011
2answers
While connecting web cam to
The camera needs more power than what the USB socket can deliver - 6 watts. Since a webcam normally uses less than 0.5 watts then either the cable or or the camera itself are defective.
Time for a new one.
7/26/2011 10:08:59 PM • ASUS M2N-E SLI... • Answered on Jul 26, 2011
I bought 4gb Ram aditional
i just looked at the specs of your motherboard it will support 2 graphics cards are/do you have both working or using only one you might need to check and make sure they are securely seated or remove the card/s and make sure the socket/s are clean and dust free the blue screens has me concerned
Support two identical NVIDIA SLI-Ready graphics cards (both at x8 mode)
ASUS two-slot thermal design
If your computer came with a motherboard disc the drivers could be on it
Click start control panel administrive tools computer management device manager scroll to display adapters + to expand you might see a yellow question mark ? or exclamation mark ! or a red x right click select reinstall drivers Want to make sure your drivers are in place and no errors have occurred? Simply click start right click on my computer select properties then select device manager scroll to Display Adapters and click on the small "+" you should see the model of your PCI Express graphic card there. If there is a problem with it, a yellow exclamation mark should appear besides it. If you don't see it everything is OK and your card is working properly.
6/25/2011 8:18:59 AM • ASUS M2N-E SLI... • Answered on Jun 25, 2011
Postavio proc 6000+ i
Pa jel si proverio da li ga podrzava ploca uopste i da li je procesor ispravan??
5/23/2011 7:17:41 AM • ASUS M2N-E SLI... • Answered on May 23, 2011
My ASUS M2N SLI onboard
If you are trying to connect through a modem/router the driver it should have come with a disk provided by your ISP you might have to connect the usb lead to your modem to get a connection then click start control panel,administrive tools,computer management,device manager scroll to network adapters should see a yellow question mark? right click install drivers http://download.cnet.com/Realtek-RTL8139-Family-PCI-Fast-Ethernet-NIC/3000- hope this helps
3/22/2011 3:55:28 AM • ASUS M2N-E SLI... • Answered on Mar 22, 2011
Video failure post beeps.. i have am2n-e sli
Hi, Thanks for using fixya.
Go into the bios stettings and check the intergrated video graphics are disabled. If you can't see the settings replace the motherboard again.
Terry
If you have any further questions regarding this matter feel free to post a comment or if you are satisfied with my answer, please give it a rating for this is the reason I do this work.
2/28/2011 1:42:14 AM • ASUS M2N-E SLI... • Answered on Feb 28, 2011
I don't have the sound
if your computer came with a motherboard disc the sound drivers could be on it you might have to uninstall then restart your computer then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling a yellow? question mark means you need to install/update driver to do this right click to install driver also click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have the correct settings there also click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer hope this helps
2/5/2011 9:28:54 PM • ASUS M2N-E SLI... • Answered on Feb 05, 2011
My pc will only start for a couple of secounds the
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ? hope this helps
1/12/2011 10:24:05 PM • ASUS M2N-E SLI... • Answered on Jan 12, 2011
ASUS M2N-E SLI (M2N-E SLI GREEN) Motherboard Logo
142 questions posted
Popular Products
Top ASUS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • ASUS Computers & Internet
Most Popular Question
dont sound
  • Computers & Internet
