20 Most Recent
Korg (KCDRW1X8X) CD-RW Burner Questions & Answers
I have a korg triton
you gotta get a scsi to scsi cable (64 pin). as well as a scsi card for youre computer,once you get those follow the manual and itll show you.
When cdrw is inserted into
try using a different type/brand of cdrw you may have a bad batch of cheap cdrw as for the freezing if this does not fix the problem
try uninstalling a few unnecessary programs then click start run type cmd then type chkdsk/f which will automatically fix any corrupt files on your hard drive then defragment your hard drive
good luck with this
When replaceing battery in 01R/W when module should be connected to power again - before or after battery replacment ?
When replacing the battery on a 1R/w module, it is generally recommended to disconnect the module from power before replacing the battery. This is to prevent any potential damage or issues that may occur from power being applied to the module during the battery replacement process.
Once the battery has been replaced, it is recommended to reconnect the module to power and perform a power-on self-test (POST) to ensure that the module is functioning properly and that the battery replacement was successful.
It is also important to check the manufacturer's instructions for the specific 1R/w module you are working with, as there may be additional steps or precautions that need to be taken. It's important to follow the manufacturer's instructions in order to avoid any damage to the equipment or to ensure proper operation of the module.
Korg EK-50 Not working after downgrading.
I this a USA keyboard, no country told. will only answer for USAredux1: simple.1: ask a shop to fix it.2: ask the maker for help KORG.https://www.korg.com/caen/3: never do downgrade, unless KORG said it is okay, and HOW. do not do that.guessing EVER.4: ask them. only They know, or find a real KORG forum we are NOT.like here?https://www.korguser.net/login.asp?OS=WIN&LAN=1&TOP=1ask there .
