20 Most Recent
D-Link RangeBooster G WBR-2310 Wireless Router (WBR2310) Questions & Answers
My dink wireless router is not work propely beause
I had a similar problem. D-Link could not resolve it over the phone. Firmware update didn't help. D-Link would not admit that the unit might be defective, so I could not resolve the issue.
Recommendation: never buy D-Link again.
10/12/2018 8:52:51 AM •
D-Link...
Answered
on Oct 12, 2018
D-Link Router Kepps Blinking When Reset
WHat is happening is the flash memory on the router is currupt and can't be reflashed.
I was finally able to reflash the device, and after I did same problem again. But this time only the basic firmware page comes up.(when the flash is currupt)
ANd every time I try to flash the new firmware it fails.
8/16/2018 6:43:44 AM •
D-Link...
Answered
on Aug 16, 2018
WBR 2310 wireless stops working.
Please reset the router and also remove the network from the devices and reconnect with the password.
for more visit www.leadingpcfix.com
2/13/2018 2:15:08 PM •
D-Link...
Answered
on Feb 13, 2018
My router restarts frequently.
restarting constantly indicates a loss of connection with the server
talk with your service provider to check the connection for continuity
10/17/2017 10:34:42 PM •
D-Link...
Answered
on Oct 17, 2017
DLink WBR-2310 freezes up with all four of the LAN
If all lights are lit regardless of anything connected then you may have a hardware failure. Try a hard reset by putting a tip of a paperclip into the small reset hole while powered on for 10 seconds. See if that resets you router - if not then it is dead.
1/7/2017 12:25:05 AM •
D-Link...
Answered
on Jan 07, 2017
Wireless signal stops working after some period of time
The final solution is a factory reset of your router. You can do a factory reset by logging into the router using you browser. Go to the settings and perform a factory reset
If you forgot the router password, you ill have to do a factory reset by locating a small hold on the back of the router and insert the tip of of paper clip for about 10 seconds while the power is on. The router will be reset to out of box status and then you can set-up form scratch.
1/6/2017 11:11:54 PM •
D-Link...
Answered
on Jan 06, 2017
Looking to set a password
Login in using your browser and go to the wireless settings and set-up a wireless password/key. Remember the key because each device will now need it to connect. You can also turn OFF Broadcast SSID and your network name will not be shown on anyone's device. You must remember the network name when using this method.
1/6/2017 9:21:17 PM •
D-Link...
Answered
on Jan 06, 2017
I have a wireless router wbr2310 and i dont have
You can download a manual or quick set-up guide from the D-Link web site support section.
You can connect to the router using a LAN cable or to wireless dlink and use the IP address of 192.168.0.1 should allow you into the set-up menu. The default router login is ADMIN and password is blank. You should be able to set-up the router without a CD.
1/6/2017 9:09:25 PM •
D-Link...
Answered
on Jan 06, 2017
How do I secure my
1/6/2017 9:01:09 PM •
D-Link...
Answered
on Jan 06, 2017
Why wont my wireless work anymore?
Try rebooting the router. Login into the router to see if the wireless is turned ON and set to FULL power. If this does not work, The final solution is a factory reset of your router. You can do a factory reset by logging into the router using you browser. Go to the settings and perform a factory reset
If you forgot the router password, you ill have to do a factory reset by locating a small hold on the back of the router and insert the tip of of paper clip for about 10 seconds while the power is on. The router will be reset to out of box status and then you can ssets-up form scratch.
1/6/2017 8:12:17 PM •
D-Link...
Answered
on Jan 06, 2017
How to setup guest access wbr-2310
Login into your router and in the wireless section you can enable guest access. On some models you can have the guest mode access only the internet, and you can select whether you want to have a password for the guest mode or not.
1/6/2017 6:55:49 PM •
D-Link...
Answered
on Jan 06, 2017
Password protect admin 192 168 0 1
One easy trick is to change the default IP 192.168.0.1 to something else in addition to password protecting the login to the modem. Make sure you save the new IP address.
1/6/2017 5:51:43 PM •
D-Link...
Answered
on Jan 06, 2017
My PS3 is asking for a wpa key code so I can go online?
If you dont know your wpa network key try to reconfigure your wireless network again.
Access the configuration page of your router.
>Type on the address bar 192.168.0.1
>On login type Admin leave password blank. if you set up a password or the login page use that one.
>Once inside the Dlink Page
>Clik Setup and on the left side click wireless setting.
>If given the option to click on manaul wireless connection setup click on it.
>Once you have the wireles window
>try to change the network name to a new one and scroll down
>Under security choose WPA security (enhanced)
>Scroll down and under the Passphrase type in your new network password or security key and confirm it.
>Click on Save Settings
>If it asks you to reboot then reboot it, if not, its ok.
11/26/2014 5:17:25 AM •
D-Link...
Answered
on Nov 26, 2014
Error 322 router not detected
For starters you could hardwire your laptop to any of the 4 ethernet ports on the router then check if you have internet connection that way, now to connect wirlelessly you need to check if there is any wireless security enabled on the router, since your already hardwired to the router you can access the configuration page of the router by typing
http://192.168.0.1 on the address bar or Internet Explorer, Firefox or Safari. When you are prompted for a username and password just type Admin for the username and leave the password blank. Now you will see the setup page of the router, select if you want to run the setup wizard or choose manual setup for configuration. On the left hand side you will see three option, Internet, Wireless Settings and Network.
6/14/2014 1:27:35 AM •
D-Link...
Answered
on Jun 14, 2014
