20 Most Recent
Sanyo HT27546 TV Questions & Answers
I have a Sanyo vizon
Reorient your antenna and put as high as possible. You might also consider getting a signal amplifier for it.
I have my cable coax connected to the UHF, VHF,
You need to put a compatible cable decoder box between the cable and TV as the sanyo will only decode analogue cable signals via the catv UHF vhf input
the digital antenna in is for digital air broadcasting signals only
Distorted picture and color problems
If when you watch tv it is fine then your problem is not with the tv. First eliminate the possibilities. plug your DVD into another tv and see if the problem persists. If it does it is your DVD. Next, replace cables. Not likely but the jack on the tv could be bad. Check those things and let me know if you have any other questions. There is more that can be checked before getting crazy.
Sanyo tv model ht27546
our year old tv plays wonderful then it will turn green an the after a while it will go back to normal .we were told that some stores put a chip in it so that after about a yr it will do that.the picture is great but then the screen turns green,what can we do to fix that?
I have a sanyo tv
Hi Henry,
You didn't mention the brand and model of your remote, anyway you may try the universal code below.
SHARP Codes: 004/ 009/ 079/ 095/ 111/ 112/ 114/ 122/ 123/ 124/ 173
Enter 3-digit code at a time.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Lost remote. closed captions on. is there any way
here is the manual
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=7eb82b548ada65fb3ed52985326223f4&modelid=311865&q=Sanyo+HT27546
go to the section
" MENU MAP "
on page 14
Fosg2000, Rate me please
I have this v it
tv signals are still in analog.....digital has not taken effect yet.
AV switch
hiya
the av on tv's are normally done automatically on detection of a video feed via the scart sockets. if yours does not have this feature then on ur remote u shud find a button that says tv/av
rik
