20 Most Recent Kyocera Copystar CS-5035 Copier Questions & Answers
try reinitializing main pcb
Kyocera Copystar... | Answered on Apr 10, 2018
www.copystar.com go to downloads. select legacy/mfp copiers. then select your model then under technical resources select drivers
Kyocera Copystar... | Answered on Aug 20, 2015
C2642 is not a listed error code for the KM-5035.
C2600 is deck conveying motor / desk motor problem.
C4200 is a LSU (laser unit) problem.
Kyocera Copystar... | Answered on Feb 03, 2015
Admin Admin /5000 5000 /Admin00 Admin00
Kyocera Copystar... | Answered on Aug 06, 2014
Username:admin Password:sharp, admin
Kyocera Copystar... | Answered on Mar 07, 2014
Run maint mode 906 to re-enable the HDD. Then run mode 024 to format. 10871087 gets you in maint. mode. 00 gets you back out. If you don't know what you are doing you will cause major problems messing around in maint. mode so be careful.
Kyocera Copystar... | Answered on Jan 02, 2014
5000
Kyocera Copystar... | Answered on Jan 01, 2014
There are a few things to check
Is your paper fresh
Open the left hand side and check the transfer roller sometimes people break the retainers and loose the springs etcwhile removing paper jams
Kyocera Copystar... | Answered on Nov 02, 2013
adjust the intensity from your print quality menu/
if that doesnt work clean the glass, sensors and paper path
If that does not work then replace the drum unit.
Kyocera Copystar... | Answered on Oct 28, 2013
Press the * key and select Machine Defaults. Key in 6482, and scroll down to Select Copy Output Mode and press the Change # key. Select the desired output location.
If 6482 doesn't work use 5000
Kyocera Copystar... | Answered on Jan 30, 2013
Kyocera Copystar CS-5035 Copier Logo
93 questions posted
Top Kyocera Office Equipment & Supplies Experts
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
Marvin
Marvin
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Kyocera Office Equipment & Supplies
Most Popular Question
need copystar cs 5035 scanner drivers
  • Office Equipment & Supplies
