20 Most Recent
2wire 2700HG-B Router (2700HGB) Questions & Answers
I can't seem to get my 2 pc to share files
Hey Capb, sounds like this "modem" is set up differently from the old one in that it is separating the wired and wireless network traffic. If you are a little technical, you might check the IP addresses of both devices and see if they are on the same networks segment.. like 192.168.1.100 and 192.168.1.101 or some such.
How do you get a Linksys WPSM54G print server to
You once have to check once that which operating system you are using and check the DHCP and firewall Settings too. You may also check Linksys router support here you get more about Routers. For more Information regarding Routers Visit:https://www.routertechnicalsupportnumbers.com/linksys-router-support/
Can i get the procedure to set up a secure
Buy Zocon-T Kit (Fluconazole/Tinidazole) is used to treat the symptoms of various va*inal yeast infections including vag*nal trichomoniasis, va*inal candidiasis, and bacterial .
2wire modem turns off
if its new then you must not have issue with it, if the configuration they gave is already setup and nothing missing, it should be ok.
If the electrical issue is true, then you try to use AVR or other power supply for your modem.
You can also try to plug it in different place and try to connect with it (even without internet) to test if its really the electrical thing causing you this headache.
"Rebooting the modem by itself is not normal" (possible hardware cause).
Otherwise, you should ask for its warranty or replacement.
Have SBCglobal with 2wire but want N wireless capability
Follow the dots -
2 wire DSL wire to back of DSL modem.
Ethernet cable out of DSL modem, to current router (if you have one).
Ethernet cable out of current router (if you have one) to new Wireless N router.
If you currently have a wireless G router, keep it, or, use the new Wireless G/N router alone. You will need to set up all security settings again if you remove your current router, and if the new router is N only, you will need to make sure all your wireless connecting computers have wireless N cards in them.
ISP problem with 2wire 2700HG-B
When I purchased the same router on Amazon I did my best to set it up on my own, but you need the correct IP information you can only get from your customer support at AT&T. I'm using this router with an old Airport card in an 2003 iBook and a 2007 iMac (built in Airport express card). The set-up was all done wirelessly, with bellsouth (AT&T) customer service instructing me over the phone, the process took about 15 minutes.
My suggestion is to call AT&T and speak with someone who knows what their doing, and they do use the SBC global page to set up the unit, starting with http://192.168.1.254/ for the system summary, from there you can set up your password etc...
