20 Most Recent Teac 1x1 DVD/CD Duplicator, DVW/D11A/KIT Burner Questions & Answers
My Teac 1x1 dvd/d11A/kit burner/Dvw/D11A: will
whatever software you are using to burn dvd;s, make sure the right burner drive is selected. if it is selected properly and still having an issue. that means the dvd writer is busted and can't detect a blank disc place into it. in that case, have it replaced.
4/5/2016 4:59:52 PM • Teac 1x1 DVD/CD... • Answered on Apr 05, 2016
2answers
When trying to copy the message reads source disc empty
Does the disk drive play the disk? If not, the drive could be faulty. If not, then the disk can bec copy protected
6/13/2014 4:49:25 PM • Teac 1x1 DVD/CD... • Answered on Jun 13, 2014
Why does my asus quietrack show sourse disc empty when it is not
The laser inside the device could be broken, i.e., not generating any laser-beam. Or, the receiver (that senses the reflection of the laser-beam) could be broken.
6/13/2014 4:47:46 PM • Teac 1x1 DVD/CD... • Answered on Jun 13, 2014
Teac_Manual
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer Close all open programs
Click on Start, Run, and type regedit and press Enter Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose DeleteAfter deleting the keys, close the registry editorReboot your computerOpen My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. or
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard or you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device hope this helps you
11/7/2011 9:28:59 PM • Teac 1x1 DVD/CD... • Answered on Nov 07, 2011
How to change the language to English on this unit
if you are talking about the language on your computer click start control panel,regional and language options select regional language options from the drop down list select the language you want also from the bottom drop up list you can select your present location location or another language hope this helps
7/20/2011 3:39:40 AM • Teac 1x1 DVD/CD... • Answered on Jul 20, 2011
Whre do I find firmware updates for a Teac 1x1
Where can I get the firmware update for the DVW-D11 ????
4/26/2011 10:04:55 PM • Teac 1x1 DVD/CD... • Answered on Apr 26, 2011
When i push copy on my DVD burner it says,Target
It happens to me also ALL the time with mine. I have a 7 disc duplicator machine I do for weddings and special events. And it's a real pain and costly to have that come up when you need the project done soon. My solution is to change the brand on the master disc. Burn another copy of the master disc on your computer to another brand and then use that brand as the new "master" in the duplicator. (1 sollution)
"Target Overflow" basically means that either sometimes the master disc has too much information on it to burn than the disc you want to copy can hold, or sometimes a CD may be in by mistake instead of DVD. If you have a Dual layer DVD disc you want to make copies of and you only have the basic 4.7GB standard DVD blank disc..it's not enough storage space on the disc to burn so you will see that error also. It should really say "not enough space to burn) lol..but I guess that's asking too much.
Sometimes all is correct with the DVD size and it'll come up for no reason (usually the master disc is still spinning and hasn't stopped but you've already pressed the "Copy" button, it's not "ready" so an error of "target overflow" will come up)
I've had mine for 6 years so I've done alot of testing and trial and error to come to the above conclusions.
I find that these brands work for the best "thorough" burns.
Recommended:
Verbatim
SONY
Ritek
Ridata
5/13/2010 7:01:24 AM • Teac 1x1 DVD/CD... • Answered on May 13, 2010
How to copy CD from Laptop to empty cd
Sounds like you made a data disk with MP3s and not an audio cd.
To play on a "regular" CD player, you should burn an audio cd.
Different burning programs have different options for this.
1/21/2010 5:39:46 PM • Teac 1x1 DVD/CD... • Answered on Jan 21, 2010
How do I get it from burning cds to burning dvds
99% of burners switCH auto from cd to dvd. just select corresponding option in burning program
10/24/2009 2:38:13 PM • Teac 1x1 DVD/CD... • Answered on Oct 24, 2009
Target drive keeps saying not ready
May I suggerst you reseat all internal connections on your drive? (Power, IDE or what ever) Make sure you are grounded to the case while you do this and you have the power cord disconencted from the wall.
Close up everything and re-connect all the stuff you disconencted.
After you do that, remove the device via the device manager.
Reboot - let windows refind the device. Have the driver CD ready if applicable.
Let me know what happens.
a
9/21/2009 3:51:42 AM • Teac 1x1 DVD/CD... • Answered on Sep 21, 2009
TEAC DVD Duplicator copies CD but not DVDs
your DVD ROM's lens has became weak.
and it cannot be repaired.
But if you manage to open the DVD ROM clean the dust in it & it will start working agaain but be careful remember that no power should be attached to ROM.
pls rate me
thankyou
2/25/2009 10:00:00 AM • Teac 1x1 DVD/CD... • Answered on Feb 25, 2009
HOW CAN I ORDER A USER MANUAL FOR MY TEAC DVW-D11 DUPLICATOR?
go to the web site,,and look up your model number,,then download the correct model manual,,and print it out.
1/17/2009 12:39:26 AM • Teac 1x1 DVD/CD... • Answered on Jan 17, 2009
Copying CDs
Trial and error, pushing buttons until I was able to do what I was trying to accomplish. I would suggest more detailed instructions in your manual.
7/23/2008 12:54:29 PM • Teac 1x1 DVD/CD... • Answered on Jul 23, 2008
Where do I hook up my Teac 1200 Reel to Reel to my Kenwood Kenwood VR309
This will all depend on the age of the equipment and what connectors are on each one. Could you post photos of the panels on them showing what connector ports are actually there. How old is the reel to reel? The really early 1970's models will probably not work or will need specialist cable adapters to get it to connect to the Kenwood and even then it may not work. The 80's and some of the 90's ones used Component, Phono or Jack Plug connectors. The really modern ones use Optical cables. In general it usually sets up by connecting to the "OUT" port on the reel to reel and the matching "IN" port on the Kenwood.
5/1/2023 7:51:37 PM • Teac Computers &... • Answered on May 01, 2023
Teac Micro-Hi-Fi CD-X8 replacement cable
11/17/2021 10:21:39 PM • Teac Computers &... • Answered on Nov 17, 2021
Hello. I have a TEAC rw-cd 22 that I have had good luck recording with. Recently, I sometimes get a no disc reading on the left tray when I am using it as the source to burn on the right tray. It reads on the right tray, so I know that it works, but the left tray no read screen means that I cannot use the left tray as a source for recording. Thanks.
There are several things that you can try. Move the carriage for the laser diode to the center area, Put a disk in and note where the label is and then eject it to see if it is spinning, check the voltage on the laser diode. This will give you an idea of what the issue is.
2/20/2021 4:33:39 PM • Teac Computers &... • Answered on Feb 20, 2021
Teac 1x1 DVD/CD Duplicator, DVW/D11A/KIT Burner Logo
28 questions posted
Top Teac Computers & Internet Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a Teac Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Teac Computers & Internet
Most Popular Question
change language english unit
  • Computers & Internet
