20 Most Recent
Sony SNCRZ25N Network Camera Questions & Answers
I can not get my dvr to conect to my home
Check your DVR network settings via the main menu function. You will require a IP Address & Passwod. Ensure your ethernet cable is connect from your DVR to your local computer.
You will then need the network viewer software putting on to your PC (normally provided with your DVR). Ensure the IP Address & your user password are entered correctly and then you should be able to connect.
Alternatively, you can utilise a web brouser.
Also have a look at the following link for a manual for the named network camera that you have indicated
http://bssc.sel.sony.com/BroadcastandBusiness/docs/manuals/usersguidesncrz25nv1.pdf
Trust all this information is of assistance.
SNC-RZ25 No Video
ADD THE SOFTWARE MANUALLY TO THE FIREWALL LIST, CHECK UR ROUTER SETTINFG FOR FIREWALL
Cannot detect configure SNCRZ25
Power supply. I tried 500 m.a. No good. 1000 m.a. @ 12volts Rocks the house. The manual fails to mention this, Since we supply our own on this model.
Sony EVI-D30 power and standby flashing
Sony EVID30 NTSC Color Camera
the battery inside is dead.
lost these? NIB, new in the had this too.
AC power adaptor (1) <<<<<???
Audio/video cable (1)
Remote commander (1)
a 2010 cam
no battery lasts 12 years for sure this one parked in dusty box for 12 years,? even 2 years ignored it can fail. hard.
new battery time.
4/12/2022 10:00:37 AM •
Sony Home...
Answered
on Apr 12, 2022
My monitor sony ssm-721 rolls until it warms up or
Fixed mine! Take off the monitor from the dash. Take the cover off the monitor. There are four seperate white plastic turn dials available inside the case. Each of these have seperate controls the ones on the top are for brightness and focus while the ones on the bottom of the casing are for vertical and horizontal hold fine tuning, use a screwdriver to adjust. Save you money and do this yourself it's easy as pie.
7/25/2014 3:23:12 PM •
Sony Home...
Answered
on Jul 25, 2014
What would be better, lightning arrestors or surge
Hello
The lightning arreseters and surge protectors are of different use. Lightning arrestors are of course high voltage dischargers, where surge protectors are use in connection with the supply voltage of the device to be protected. A lightning arrester cannot give protection against line surge voltages. Line surge voltages are the result of various other electrical equipments, connected to the specific line, susch as high capacity motors, or so. When a motor is switched on to a line, its winding will take a tremendous amount of current during startup, and due to this a spike will be induced on the line, which may cause damage to delciate electronic equipents. Therefore, to protect and electronic equipment from line surge, surge protector is better. A lightning arrester also can be installed. As we know, there will be trillions of volts during a lightning discharge. Lightning arresters are not discharging this at one time, but discharges it slowly to ground, and thus avoiding the chance of a sudden discharge. Nothing of the above can prevent a sudden lightning discharge at all. OK.
4/28/2011 4:16:48 PM •
Sony Home...
Answered
on Apr 28, 2011
