20 Most Recent Sony KDS-60A2000 60" HDTV Questions & Answers
STANDBY INDICATOR LIGHT BLINKS 15 TIMES WHEN TV IS
Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast.It's major symptoms are clicking,electrical sounds,shuts off and on and get the lamp indicator.But if you don't hear any strange noises,tv is around 6000 hrs,2-4 yrs,It's major symptoms are clicking,electrical sounds,shuts off and on and get the lamp indicator, it could be time to replace the lamp.
10/8/2022 5:50:59 AM • Sony KDS-60A2000... • Answered on Oct 08, 2022
0answers
Optical output, no sound!
Have you selected Optical output from the audio setup screen of the TV? That needs to be selected to transfer TV audio to the optical out of the TV.
7/28/2017 7:03:18 PM • Sony KDS-60A2000... • Answered on Jul 28, 2017
Red power light flashed 5 times
There is no color wheel. This is an SXRD TV. If you have 389 at the ballast, then your ballast is bad. 5 flashes is a bad lamp driver. No TTL signal return to the mainboard. Put a new ballast in. Do not try and measure ballast output without good high voltage gear. The startup pulse is close to 20,000 volts.
9/30/2016 8:08:45 PM • Sony KDS-60A2000... • Answered on Sep 30, 2016
4answers
Picture is getting Yellow screen on botton right corner.
Sony extended Optical Block until 06/302010. Will re-imburse your if you replaced the optical block out of your own pocket
from http://esupport.sony.com/US/perl/news-item.pl?news_id=277
Certain 2006 Model Year SXRD Television Extended Warranty Information – Optical Block
Posted: 10/21/2008
Models: KDS-50A2000, KDS-55A2000, KDS-60A2000, KDS-R60XBR2, KDS-R70XBR2
Aspart of the Sony commitment to quality, Sony is announcing that it isextending the limited warranty (parts and labor), in the United States,on the optical block of the above-referenced 2006 model SXRDtelevisions until June 30, 2010, regardless of purchase date. For anycustomer who requires repair of the optical block on one of theaffected models, Sony will cover the cost of the optical block repair(parts and labor) at no charge through June 30, 2010. This extendedwarranty does not apply to the replaceable projection lamp or the otherparts that may be used in the televisions.
Sony is also announcing that for any owner of these modeltelevisions who paid out-of-pocket expenses on or before November 30,2008 for an estimate or repair service to replace the optical block,Sony will reimburse the customer by mail for the cost of the opticalblock and the labor expense to replace it, subject to certainconditions. To receive reimbursement, please follow completely thedirections on the claim form for reimbursement; all claims must be postmarked by January 31, 2009. See the claim form for complete terms and conditions.
All other terms of the Sony limited warranty continue to apply. Sonyutilizes a network of hundreds of qualified independent third-partyservicers to perform in-home television warranty service. Sony, throughits authorized servicer network, will endeavor to repair your setwithin 30 days of your first contact. For diagnosis, warranty service,or if you are not provided a repair within 30 days, please contact Sonyat (888) 649-7669.
7/3/2016 11:46:31 PM • Sony KDS-60A2000... • Answered on Jul 03, 2016
How do I bypass lamp door sensor of wega tv
Look for a small switch that is pressed when the door is insert/closed. Close the circuit and it should work.
6/27/2015 9:19:25 PM • Sony KDS-60A2000... • Answered on Jun 27, 2015
3answers
Replaced lamp in sony sxrd 50 inch rear projection and getting 3 red blinks for lamp door not closed ..have taken off and put on several times with same results..any suggestions?
Sony Lamp issueI see this so much that I am going to compose and save this answer:3 blinks (it is in the owner manual) is "Lamp door not properlyclosed".What is really wrong is if you remove the door and look edgewise it will likely be warped from the heat from the lamp.1. On most of these but not all SONY knows of this and offers on many models to repair or replace the set for free---somemodels the heat also warps the area thelamp inserts in.2. If you look at the back of the door there is a small plastic peg--it whendoor is installed engages a lever (small and designed to prevent the set frombeing used if door is open).3. The way to prove if door is the problem is to with something not metalengage and hold the lever where the peg goes (you will have door off and alsothe large front plate giving access to lamp) and turning set on.IF SET COMES ON AND WORKS DO NOT LOOK AT THE LIGHT FROM THE LAMP as it candamage your vision.DO NOT OPERATE SET FOR A PROLONGED TIME WITH DOOR REMOVED OR THE FRONT PLATE(that covers access to lamp) attached as the heat with door removed can damagethe outer plate.4. If set works then you have a few choices=Google the model number with"lamp door" or order it from Sony and replace it.Please feel free to comment here (make a comment button) if you have questionsor concerns and it is important to me to know if this helped you or not
5/26/2015 8:15:34 PM • Sony KDS-60A2000... • Answered on May 26, 2015
Power led flashes red 3 times
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/ Blinking codes details to many popular brand TVs are given. Surf the site with patience.
1/29/2015 9:58:03 AM • Sony KDS-60A2000... • Answered on Jan 29, 2015
2answers
I HAVE A SONY KDS-60A2000
3 times red light blinking indicates that Lamp Cover has not been fixed in its location properly after lamp replacement.
Please make sure lamp cover (its first thing that was removed to replace lamp) is installed securely.
Thanks.
11/10/2014 11:22:49 PM • Sony KDS-60A2000... • Answered on Nov 10, 2014
Sony sxrd problems
bad power supply. Contact SONY for advice. They will pay for the repair and service call if it is still under warranty
7/31/2014 10:17:19 PM • Sony KDS-60A2000... • Answered on Jul 31, 2014
Sony KDS-60A2000 - no sound.
please re setup it ! or hit fingers on the speakers if not worked then go to the sony searvice centre and check it there is a loose connections !
3/19/2014 1:06:01 PM • Sony KDS-60A2000... • Answered on Mar 19, 2014
0answers
Power on light flashes red
You need a new bulb.
11/25/2013 5:43:07 PM • Sony KDS-60A2000... • Answered on Nov 25, 2013
Sony KDS-60A2000 60" HDTV Logo
191 questions posted
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Televison & Video
Most Popular Question
sony kds 60a2000 no sound
  • Televison & Video
