20 Most Recent
Radio Shack Pro-97 Handheld Scanner Questions & Answers
Problem with Pro-2066 scanner not receiving local
It is difficult to explain in simple terms but I will try.
Google rebanding.
Some radios can have their firmware updated but I don't think your PRO 2066 can.
Channel numbers and frequencies preprogrammed into your scanner have changed over the past few years.
When a data signal says go to channel X that channel is now Y, but your scanner is still looking for X
Hope this helps
Police frequencies michigan
Hi, must have a digital trunking scanner first and foremost if you want to monitor the state radio frequencies. You much has a ham radio license or 'permit' to use the scanner or even have the scanner in you car. You can sign-up for a premium membership at Radio Reference dot com and it will set you up with direct loads of frequencies and talkgroups. Here's a link to help you:
https://www.radioreference.com/apps/db/?stid=26
I turn on my pro -97 Handheld Scanner and it displays all channels are locked
Turn the scanner on and make sure that you don't see a "key" in the display- if you do, you first have to press and hold the key LOCK button until it beeps and allows you to use the keys. press 'manual'. press and hold 'L/O' 'lockout' for 3 seconds and it will unlock all locked out channels. now press 'scan'. if you have nothing, then press 'scan' again and press each one of the number keys to turn off and to switch on the scanning banks. Okay? Let me know if you need more help.
WHERE IS THE BUTTON i PUSH TO UNLOCK ALL CHANNELS
turn the scanner on. press 'manual'. press and hold 'L/O' 'lockout' for 3 seconds and it will unlock all locked out channels. now press 'scan'. if you have nothing, then press 'scan' again and press each one of the number keys to turn off and to switch on the scanning banks. Okay? Let me know if you need more help.
All channels locked out
Press scan, then press a number button and it will scan that bank -pick a number from 0-9 and it should scan that. If you did truly lockout everything hit 'manual' then hold down the L/O Lockout button for 3 seconds and you'll hear a beep- that should unlock everything.
Cant pick up stations
Most police stations are using the new motorola trunking units, they are on encrypted custom band channels and you will not be able to hear them. All police helicopters are equipped with them. All i can hear where i live is Fire dispatch, I cant even hear the fire fighters responses .
POLICE SCANNER FREQEUNCIES
finding the frequencies is pretty straight forward...
here's one easy solution..The simplest way is to GOOGLE.
go to google.com
enter "radio frequencies" and your county name and state..
you'll get the links to posted municipal services' radio freq's.
Then simply enter them into your scanner memory...
If you need the "10 codel" definitions, you can get those too so that you'll fully understand what all their abbreviations mean...
Have fun..
