20 Most Recent
Samsung HL-S4266W 42" HDTV Questions & Answers
DLP television
Hello. If you haven't changed the lamp lately, or if you used an aftermarket lamp, that could be the problem. If the lamp is ok, the ballast may have a bad capacitor. A bad capacitor will be puffed up on top. The ballast can be found by following the leads from the lamp. If it's not those, then the color wheel could be defective, and you might be able to hear it making a noise. I hope that helps.
8/10/2016 3:42:51 PM •
Samsung...
Answered
on Aug 10, 2016
Would a cracked screen cause no picture
Would you be able to provide the model number of your TV to provide you with more info?
If your TV is a DLP, the lamp would need to be replace to get the picture working again.
5/7/2014 3:47:34 AM •
Samsung...
Answered
on May 07, 2014
Samsung 32 "lcd has pwer but wont turn on
To begin someone needs to open and look at the power board for signs of any damaged parts or puffed up filter caps, this is where to begin, if you are not able to do that consider getting it looked at by a tech or a shop.
12/14/2012 4:26:39 AM •
Samsung...
Answered
on Dec 14, 2012
Samsung HL-S4266W says to Check fan #1. I replaced it and it is running fine, but it still says it. Help!
Either something has to be done to clear that error or the set is detecting something.I have a comment/suggestion here. that error may be misleading you, when you replaced the fan was there a noticeable amount of dust in the set---not like inside a carpet vac but noticeable.I have seen this before in more than one set and brand---first thing we do is roll set outside (I know its getting to be winter) and with the cover off use compressed air and dust the whole set out--don't do it inside as even if set looks fairly dust free it may look like a dust storm when you do this.I have seen many where units were dead or shutting down etc where once the air channels (unit takes in air from front and exhausts it toward the rear) I have a working set with no issues.this is from experience and I hope it may help.SD TECH
12/6/2012 3:09:13 AM •
Samsung...
Answered
on Dec 06, 2012
Tv keeps shutting off. Currently no soud or picture
The set has a color wheel which may be bad, it often makes a high pitched or fan like sound prior to failure--it can even be a grinding noise.I would with set unplugged remove the lamp cartridge and look where it faces---the color wheel can be seen.What you are looking for is wheel shattered or missing any of the colored segments? If wheel does not turn or runs too slow set will detect this and shut lamp off etc.
8/29/2012 5:52:08 PM •
Samsung...
Answered
on Aug 29, 2012
Clcking noise when turning tv on. tv takes about 15 to 20 seconds to come on.
That is a clicking noise came from the relay. This kind of symptoms is an indication of faulty electrolytic capacitor on the power supply board.
Inspect the encircled capacitor, most of the faulty electrolytic capacitor bulged at the top, if you can't see any bulged or dome at the top you must have a capacitor checker to determine its condition.Replacing the entire power supply board is another option if you are not comfortable in electronics.
11/23/2011 10:59:35 AM •
Samsung...
Answered
on Nov 23, 2011
Samsung tv keeps turning off
I had this problem. It cut off and front panel lights were blinking. Replaced bulb with a phillips OME bulb. Part # is on TV. Cost was about $100.
9/16/2011 2:49:43 PM •
Samsung...
Answered
on Sep 16, 2011
Tv comes on for about 10-15 seconds then shuts off
You have a power supply circuit issue.
Possibly a component in the primary side of the power regulating circuit for power on is weak or defective.
You unit will require a tech to look at the power section of your TV.
8/12/2011 2:51:33 AM •
Samsung...
Answered
on Aug 12, 2011
Tv turns on about 30
Bad lamp again. The lamp life is not dependent on install date but more the amount of use. Ebay for the lamps, a lot of the time you can get them 50% off for refurbs.
7/30/2011 12:43:43 PM •
Samsung...
Answered
on Jul 30, 2011
