20 Most Recent
Behringer (UCA202) Sound Card Questions & Answers
How do I record my cassettes into my PC
find a tape player/recorder than has the capability to connect to a computer connect your tape player/recorder to your computer open windows explorer navigate to the tape player open it then select the files you want to copy to your computer right click select copy then navigate to the place where you want them saved or you can select the files hold the muse cursor on them drag them to the place you want to save them and drop them into it
hope this helps
7/30/2013 7:35:30 PM •
Behringer...
Answered
on Jul 30, 2013
Hi.I just want to know if my Behringer UCA202 can
It is a low cost alternative. It can be used as an interim choice until you get a true audio interface tailored for a recording studio. I use them to connect to my laptop for recording group mixes for live performances on a bus mix. It works well for that type of application. It has quality sound recording and playback at CD quality.
11/1/2012 10:56:35 PM •
Behringer...
Answered
on Nov 01, 2012
My computer doesn't register this device at all.
click start control panel administrive tools ,computer management ,device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
if your computer came with a motherboard disc the sound drivers could be on it
you might have to uninstall then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable)
hope this helps
1/27/2011 10:41:54 PM •
Behringer...
Answered
on Jan 27, 2011
I have a Behringer UCA200
Hi! You will need a different product. I suggest that you do the sound convertion via SONY SOUND FORGE. This gives better sound quality and you can choose any file size you want. Hope this helps and have a good one!
8/4/2010 7:35:59 PM •
Behringer...
Answered
on Aug 04, 2010
Connection
first install driver, plug in usb port of your laptop
4/11/2010 4:17:44 AM •
Behringer...
Answered
on Apr 11, 2010
How to connect mixer 100 fx to uca 202 and laptop
Just connect:
one output from 100fx to uca202 line in. Connect an output that corresponds what you want to get (e.g. if you're going to record something use record out or main out)
one line input from 100fx to uca202 line out.
the USB cable from uca202 to your laptop's USB port.
The solution is the same (in general) whatever mixer you may have.
Normal
0
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"????????? ???????";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0cm 5.4pt 0cm 5.4pt;
mso-para-margin:0cm;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";}
In case of
a problem or clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
2/25/2010 6:57:10 AM •
Behringer...
Answered
on Feb 25, 2010
UCA202 no longer recognized after new drivers installed.
hi, the the drivers are not signed and caused stability issue, (blue screen) the device itself is not actual hardware(audio codec) my recoding software could not set it up. you can do as i did and get abetter unit for about 20 bucks more.. hope this helps.
2/12/2009 6:32:14 PM •
Behringer...
Answered
on Feb 12, 2009
Behringer uca 202 not recording
i also had trouble at first,and fought with it all the time! as it is not a great item. my recording software could not set it up, as it is not actual hardware.(audio codec) make sure the controls are not muted and the slide bars are set upwards. also the drivers from behringer are not signed! and could cause stability issue. you may want to do as i did and get a better unit, (about 20 bucks more) hope this info helps, good luck!
2/12/2009 6:26:17 PM •
Behringer...
Answered
on Feb 12, 2009
