20 Most Recent
Pioneer PL-990 Turntable Questions & Answers
Pioneer htp-072 vsx-324--k-p
What receiver are you using and what input have you plugged this into? For more information, or should you have any further questions, please visit my website at audioserviceclinic.com. You may contact me directly through the website. Thank you.
Need dust cover for pioneer pl-990 turntable
The only place to order one, is at Pioneer USA, as they have no distributors. It may or may not be available at this time. For more information, please visit my website at audioserviceclinic.com. Thank you.
Pioneer turntable to Pioneer VSX 515 receiver
I'm not sure what you mean by "Wot", but I assume you mean that the receiver doesn't have a phono input, as most receivers now a days don't. You will need a phono preamp. Cost is under $25.00. It provides the amplification to be able to use any high level(CD, DVD, AUX, etc) input as well as the RIAA equalization you need to decode the record correctly. For more information, please visit my website at audioserviceclinic.com. Thank you.
How to adjust the speed using the lights.
When the turntable spins the light shines on the edge. You will see at least two indications. One for 45 and one for 33. With the record playing you should adjust the speed control, till one of the indents appears static and not moving. You will have to do this for both speeds. You also might see some varations in speed. These are quite normal and getting it right is trial and error. It will only read true when the stylus is on the record too. If you can't get the indication to stay still then there is something wrong with the drive.
Pioneer PL-570 turntable (c.1973)
Yes first check is that the Gnd wire from your turntable is connected to the Gnd (ground) post at the back of your amplifier with a good clean tight connection.
If the problem persists, check ALL your hi-fi components mains plugs for earth connections including your turntable, then remove the earth connections on all but one component so that you are left with only item earthed.
What does sometimes cause problems is if 2 or more hi-fi separates are earthed and connected to each other the earth cables along with the hi-fi interconnects form an inductive loop that picks up interferance such as mains hum etc.
Regards John
