20 Most Recent Sony PS-LX250H Turntable Questions & Answers
10answers
Sony PS-LX250H turntable speed adjustment on underside, how??
Great detective work.
Let's collaborate on this for the benefit of others who may have the same problem.
L.IN should be the point at which the Lead-In groove on the LP would be, where the tonearm will drop to play an LP
RET should be the point at which the tonearm will lift up and RETurn to its rest at the end of the LP
That leaves us with SW. If your source is right this will affect the Speed. I can't imagine what the W stands for.
Since this turntable lacks the traditional strobe light and dots along the platter rim for determining if it's on target speed-wise we have to improvise and make a Strobe Disc.
It has radial marks on it and you place it on the turntable like a record. The lights in your room running at 60hz will make it appear to be stationary if the speed is correct; slowly creeping CW if too fast; CCW if too slow.
Here's a link to a PDF from which you can print your own disc... http://www.extremephono.com/ftp/60Hz.PDF
Here's what you do. Lay the trimmed Strobe Disc on top of a record while it's playing one of the outer tracks. This is because the stylus imparts some drag so we want to factor it in.
Then adjust the screw exactly one turn Clockwise and note how the speed has changed. Trial and error should get you to where you want to be.
8/26/2023 4:08:41 AM • Sony PS-LX250H... • Answered on Aug 26, 2023
Why does my turntable not spin when I move my Tone arm over?
Hi Daniel, its a bit of a long shot however try this. With the turntable powered of manually rotate the platter approx 12 times to reset the auto operation back to default. John styluscity.com
1/7/2023 7:09:20 PM • Sony PS-LX250H... • Answered on Jan 07, 2023
4answers
My Sony PS-LX520 turntable skips with tone arm not moving
Check the needle, if its not that then you can check the tracking, the relationship between downward weight on the needle and lateral movement across the record. you will need the manual for the instructions
It can be tricky so if you are not sure then consult a good hifi shop or tech.
Hope this helps
Thanks for using FixYa
8/29/2022 1:51:15 PM • Sony PS-LX250H... • Answered on Aug 29, 2022
My audio technica turntable is
there are two small holes under the unit labeled 33 and 45 that control speed. im guessing youre mainly playing lps so use a flathead jewlers screw to adjust the 33 setting until you get the right speed
5/21/2019 2:26:13 AM • Sony PS-LX250H... • Answered on May 21, 2019
2answers
When I press Start the needle moves over, drops down, then comes back up and over and stops. It does this about 95% of the time.
did you try placing the needle on the record manually? Did it work okay then or did it do as you mentioned?
11/25/2017 7:48:45 AM • Sony PS-LX250H... • Answered on Nov 25, 2017
Plays too fast
Either the speed switch is history or there is a belt problem. Get rid of it.
7/27/2017 1:30:10 AM • Sony PS-LX250H... • Answered on Jul 27, 2017
HOW DO WE REMOVE THE STYLUS TO REPLACE IT FROM THE
You should be able to pull down on the front of the stylus and then pull it out from the cartridge. There is no weight adjustments on this model.
5/17/2017 10:58:09 AM • Sony PS-LX250H... • Answered on May 17, 2017
I have a Sony PS-LX250H that was put into storage and moved twice while I was in transit between residences. Since I got to my new place I haven't been able to get it to work at all even after rep
hi check the belt it might be loose... elasticity of the belt is ... no more :( try turning the plate by your hand and see what happens Good Luck
5/9/2017 7:59:15 PM • Sony PS-LX250H... • Answered on May 09, 2017
Wont switch off after record finish
The auto return radius requires adjusting
2/23/2016 1:45:26 AM • Sony PS-LX250H... • Answered on Feb 23, 2016
How do I adjust the speed of a Sony LX250H turntable? The answer is not in my manual.
Presumably you mean correcting the speed to play 45 and 33 correctly? Some turntables have the speed control(s) as a preset(s) built into the base on the underside of the unit. Often covered with a sticker. You simply remove the sticker and stick a small screwdriver in the thing and turn it. Others have the preset inside on a circuit board, got to by removing the bottom of the turntable. Others have it built into the motor itself. You should replace the belt first if the speed is slow on both 45 and 33, before adjusting the motor speed.
9/4/2015 12:06:21 AM • Sony PS-LX250H... • Answered on Sep 04, 2015
How do i put the belt back on my sony turntable?
There's a video guide here:
8/3/2015 1:06:14 AM • Sony PS-LX250H... • Answered on Aug 03, 2015
The turntable runs great for half the way throw the lp and then it speeds up to a 45 speed
Any infinitesimal change in belt temperature would not cause such a change in speed. The speed of your turntable is governed by an electronic circuit and this is where the trouble is. The cost of a repair is going to be mostly labor which may exceed the value of the value of the turntable.
3/16/2015 6:24:55 PM • Sony PS-LX250H... • Answered on Mar 16, 2015
4answers
New needle for sony ps-lx250h?
Yes It's possible.You can purchase it on amazon, click here and take a look: Amazon com sony ps lx250h needle. I hope this was helpful. Cheers
12/25/2014 12:14:50 AM • Sony PS-LX250H... • Answered on Dec 25, 2014
Sony PS-lx250h
Most likely the belt has come off or is worn. To replace a drive belt. Before starting unplug from mains power source. 1, Remove the rubber platter mat to expose the platter. 2. Put your thumb and forefinger through the two round holes and lift the platter off. You may need to give the centre spindle a light tap (whilst applying upward pressure) with a screwdriver handle or some similar tool that will not leave any marks or damage. 3. Remove the old belt and wipe the platter pulley and motor pulley with an alcohol swab to remove any old belt residue. 4. Place the new belt around the platter pulley making sure t is sitting flat without any twists. 5. Flip platter over the right way up. There are1or 2 larger rectangle shaped cut outs in the platter. 6. Through the cut out pinch up the belt and slip a finger or belt hook between the platter pulley and the belt gripping the belt ready to fit over the motor pulley. 7. Align the centre hole of the platter with the spindle and place platter back into position keeping a grip on the belt. 8. Slip belt over motor pulley and give the platter a light clockwise rotation to ensure the belt is riding correctly. 9. Replace the rubber mat and then run the turntable to ensure correct operation. Job done.
11/14/2014 11:13:13 AM • Sony PS-LX250H... • Answered on Nov 14, 2014
4answers
Platter/motor won't turn
I don't know the answer, but you have written one of the finest, most comprehensive problem descriptions I have come across. In mechanical scenarios, that is priceless. I'm sure a turntable guru will see it and go, "aw. I know what that is". Good Luck.
8/21/2014 3:43:15 AM • Sony PS-LX250H... • Answered on Aug 21, 2014
When playing records on my turntable, the right
Check the wires to the cartridge, they can come lose and need to be tight. If that doesn't solve the problem check or replace the connecting cables. You can confirm it's not the pre-amp of your amp by just swaping the cables. Then the left speaker should play up. If it is still the right, then there's a fault on the pre-amp. But it could be just bad soldering somewhere. Also take the bottom of the turntable and check the soldering of the cables inside it.
8/17/2014 1:10:04 PM • Sony PS-LX250H... • Answered on Aug 17, 2014
Sony PS-LX250H Turntable Logo
213 questions posted
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
ZJ Limited
ZJ Limited
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Audio Players & Recorders
Most Popular Question
sony ps lx250h turntable speed
  • Audio Players & Recorders
