20 Most Recent Teac GF-650 Turntable Questions & Answers
CD drawer will not open
Try manually opening the drawer. There's a little hole on the front, Insert a pin or bent paper clip in the hole with the machine "on". Should open for you.
8/3/2014 12:28:14 PM • Teac GF-650... • Answered on Aug 03, 2014
B210 belt
If you have the original measure the Diameter in mm and also the width in MM. You don't have to be spot with these measurements. Then put the words "turntable belt XXmm (diameter) into Google. You should find something, you can narrow it down by adding the width, but I would just try the diameter first. If you need to remove the belt make a note of how it fits first!
7/20/2013 1:35:10 AM • Teac GF-650... • Answered on Jul 20, 2013
0answers
0answers
Teac turntable plays too fast
This sounds like a motor speed control problem. It could be either the motor itself or an electronic fault. So unless you know a bit about electronics and know how to use a soldering iron etc, then the answer to your question is no.
10/24/2009 11:22:07 AM • Teac GF-650... • Answered on Oct 24, 2009
Turntable runs a bit too fast
LOL, The Chipmunks rock!..j/k
Sounds your player isn't reconizing your settings, therefore the switch that controls them could be shot.
Firstly consult the troubleshooting section of your manual
If you have have no manual to reference, check this site for a downloadable one.
If still no, then visit the Teac home page and follow the support/troubleshooting/customer service links there.
There also you will find listings for any authorized repair shops in your area where you can have it looked at and a new switch installed, should that indeed be the issue.
Conversely to that, call the toll free number you will find in your manual or on their website for assistance.
Wishing you luck and... no more Chipmunks...
10/6/2009 7:09:09 PM • Teac GF-650... • Answered on Oct 06, 2009
Teac GF-650
hi, please if you can open the turntable unit ,go on the part of power supply please double check the fuse first...maybe that is the solution for your problem...find the supply section ... you can find it from the AC plug going to the deck end..u
7/9/2009 3:33:43 PM • Teac GF-650... • Answered on Jul 09, 2009
GF-350
is it possible to fit a new laser unit to my GF350
11/14/2008 1:33:43 AM • Teac GF-650... • Answered on Nov 14, 2008
Volume
LPs were mastered back in the day with no real volume standard--ceertain sounds had to be mastered light because the engraving on the master disc was so sensitive.....digital technology does not have that problem....digital takes a lot of volume before it starts to break-up...
rick12string
1/3/2008 12:22:13 PM • Teac GF-650... • Answered on Jan 03, 2008
Is there a service manual for a teac agv1020 receiver?
If you are not a TEAC service agent, they are available to purchase; https://www.servicemanuals.net/en/TEAC-AGV1020-Service-Manual
2/15/2024 12:51:29 PM • Teac Audio... • Answered on Feb 15, 2024
2answers
Where can I get a user's manual for a TEAC AG-V8525
You could try searching on on google
1/31/2024 1:34:28 AM • Teac Audio... • Answered on Jan 31, 2024
My display won't turn on every other light does but no sound comes out of speakers
Check mute is in off position. If problem persists, the check plus minus 5V supply section and measure voltages at IC30. Here is service manual for help. TEAC AG-D9100 D9200 SM Service Manual download, schematics, eeprom, repair info for electronics experts (elektrotanya.com) Here is user manual for help Troubleshooting - Teac AG-D9100 Manual Del Usuario [P?gina 26] ' ManualsLib
1/19/2024 12:02:17 PM • Teac Audio... • Answered on Jan 19, 2024
Is the Teac CR-H100 a unit that can be repaired?
The repairability of the Teac CR-H100 depends on the specific issue it's facing. Many electronic devices, including audio units like the Teac CR-H100, can be repaired if the problem is identified and if replacement parts are available. It's recommended to contact Teac customer support or a certified technician to assess the specific issue and determine the feasibility of repair based on the unit's condition.
1/1/2024 6:49:09 PM • Teac Audio... • Answered on Jan 01, 2024
I have a teac nostalgia GF 680. When I turn on a record, no sound comes out. What can I do?
See troubleshooting section on page 30 of manual. It may help. GF-680(EF) (teac.jp)
12/31/2023 10:20:06 AM • Teac Audio... • Answered on Dec 31, 2023
Teac NP-H750 takes a long time from powering at wall to going into standby / ability to switch on.
Here are some troubleshooting steps you can try: Power source and wiring: Make sure you are using a reliable power source and the correct power cord for the Teac NP-H750. Sometimes using faulty outlets or wiring can slow down the power on time. Firmware update: Check if there is a firmware update for the device. Manufacturers regularly release firmware updates to fix performance issues and improve performance. Updating the firmware can help fix the slow power-on. Reset the device: Try a factory reset on the Teac NP-H750. This process can help eliminate any software bugs that may be causing the slow startup. Network connection: If your Teac NP-H750 is connected to a network, check the network settings to make sure you have no problems connecting to the Internet. Sometimes network issues can delay the startup process. Check for hardware issues: Inspect the device for any damage or loose connections that could cause a delay during power on. Check the power button and other controls carefully for proper operation. Power saving system: Check the power saving system on the Teac NP-H750. If the device is set to quickly go into standby mode, it may take longer to turn the power back on. Use Support: If none of the above solutions work, consider contacting Teac Customer Support or their Authorized Service Center for further assistance. They may have specific troubleshooting problems or know general issues with your model. Please note that products must be made with care, as modifications to the product or unauthorized repair attempts may void the warranty. If your Teac NP-H750 is still under warranty, it is best to contact the manufacturer
8/4/2023 8:49:23 AM • Teac Audio... • Answered on Aug 04, 2023
Does anyone know where I can purchase Teac Part No. 1977182R-50 or if there is an alternate that will work?
You give no clue what the part is, but a link to TEAC spares is in the link. https://www.google.com/search?q=Teac+Part+No.+1977182R-50 All questions need 'make model (what it is) please for the host item and what you are looking for. The link suggests it is the optical drive and they are readily available. ..
6/27/2023 10:19:31 PM • Teac Audio... • Answered on Jun 27, 2023
Teac GF-650 Turntable Logo
11 questions posted
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Teac Audio Players & Recorders
Most Popular Question
turntable runs bit fast
  • Audio Players & Recorders
