20 Most Recent Sennheiser CX 300 Consumer Headphones Questions & Answers
yh im having the same problem good to know its not just me
Sennheiser CX... | Answered on Nov 02, 2019
It's likely the groud connection in the cable is broken. Possibly at the plug, it would mean no centre focus and no bass as the headphones get only out of phase sounds. I'm guessing you've tried them in another device - a faulty sockey would do the same.
Sennheiser CX... | Answered on Jan 21, 2018
This confirms that the wire is open on the inside and so the only job out for you to to have a close SURGERY to be done to rectify .
You must dissect the wire to see the inside layers, now as you tug the free state of the wire will confirm the position of the wire break. Cut and **** the wire sleeve to see the strands where it has come off, use a good soldering iron to solder after cleaning of the wires. Insulate the joints properly with tight taping and bind them together so that the fault will not recur.
Sennheiser CX... | Answered on Mar 19, 2011
You can find the answer by clicking my user name and looking at the tip for headphones.
Sennheiser CX... | Answered on Feb 19, 2011
There is a poor connection in the headphones, they are not really designed to be repaired, but you have nothing to lose by trying as they may end up in the bin either way. Not what you wanted to hear sorry.
Sennheiser CX... | Answered on Jan 11, 2011
well... you just have to take off the ones that are on... and then replace them with the desired ones... smooth action ;)
Sennheiser CX... | Answered on Dec 13, 2010
Contact sennheiser. You may need to have it replaced. The problem is with your audio jack.
Sennheiser CX... | Answered on Oct 14, 2010
had the same problem with the right ear bud and I don't know if it is suggested in the manual, but cleaning the mesh on the ear bud with a cotton stick dipped lightly in alcohol (almost dry) helped with me, the sound is back 100%.
I hope it helpes with your too.
Mykab
Sennheiser CX... | Answered on Sep 07, 2010
You could have a look at my tip on repairing dodgy cables and plugs on headphones. Though if it will be any good with your type of headphone, is up to you to evaluate.
Sennheiser CX... | Answered on May 12, 2010
This is normal. The company designs them so that the cord hangs down one side to your music player/radio, etc. If you look at the headphones, there is an "L" and an "R" on each earpiece, put them in the correct ear and you've got them on correctly for proper stereo sound.
Again, the reason one cord is longer than the other is to allow for the cord to hang down one side to your player. Sony and many other 3rd party earphone makers also have similar designs, while there are some that still use the center cord and equal length ear piece cords.
Hpoe you found this very helpful, and best regards!
Sennheiser CX... | Answered on Jan 29, 2010
I have been having the same problem for the past week, I have just fixed it, reading your post gave me the idea to clean them and it actually worked
What i did was to "heat them up" with a hair dryer so that any wax from my ear that had gotten inside would "melt", then I cleaned them with alcohol and a q-tip and I made sure I let a bit of alcohol to get inside the ear bud, then I dryed it with the hair dryer again very carefully and tested to see the results and WHALA works just fine
Sennheiser CX... | Answered on Jul 15, 2009
Sennheiser CX 300 Consumer Headphones Logo
Popular Tags
31 questions posted
Top Sennheiser Audio Players & Recorders Experts
Michial Gueffroy
Rob Beech
Are you a Sennheiser Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Sennheiser Audio Players & Recorders
Most Popular Question
after replacement ear pads sennheiser
  • Audio Players & Recorders
