20 Most Recent
Toshiba 56HM66 56" Projection HDTV Questions & Answers
Toshiba 56hm66 yellow light blinks 15 times
unfortunately I don't have any solutions for you. I have just started to have the same problem and have only replaced the lamp. i was going to move on to the ballast but wouldn't want to if it going to be a waste of time. Did you ever find any way to resolve the prolem?
Color wheel
the motor for the colour wheel may be warn out or coated in dust. motors can go weak at any time. they usaly need to be replaced after 2-3 years.
Fan runs after tv has been turned off.
Per the manual, page 2
http://www.manualowl.com/m/Toshiba/56HM66/Manual/33146?page=2This TV contains several cooling fans to moderate the internal temperature. You may be able to hear the fans for several minutes after the TV is turned off. This is a function of the Quick Restart feature and is not a sign of TV malfunction. You can set the Quick Restart feature to stop the fans as soon as the TV is powered off. See "Setting the Quick Restart feature" (- page 20).
Toshiba 56HM66. Picture freezes, then picture goes
this is a digital board problem. Part# 75004946.
has to be data transferred from dmd board. options menu in service mode. scroll down to dmd>digital transfer. press left arrow on remote to initiate. when says ok exit on remote an shut off................. Meder's Tv
Toshiba 56hm66 dark screen
I seem to remember this issue in their sets, might want to spend some time with the model number and search "problems" as I have seen this in one of these before---several thousand sets ago.
