20 Most Recent
Alpine CDA-9883 CD Player Questions & Answers
What is the mx mean on radio and how do i go into this function
Here's a great explanation of the mx feature from a review of the alpine decks... "Media Xpander (MX) is a great feature. If you
listen to lots of MP3s, you know the quality on some can leave a bit to
be desired. Media Xpander helps compensate by adding bass and tone to
your files. And you can control the level of ‘help’ you want (from 1-3,
mine sits at 2 except for the worst discs). Even my worst bootlegs
come out sounding pretty decent – and you can use it on both CDs and FM
radio." hope that helps you put it to good use!
When head unit is on tuner everything is fine when
are you using an amplifer? if so, it sounds like you are using the blue wire instead of the blue/white wire to turn the amp on. the blue is antenna remote and turns of when it is not in tuner mode. the blue/white is amplifier remote.
I have hooked up the
I bet the channels are burn up. Try hooking it up thru the amp. (using the rca's)
I just returned from
you might want to check all the fuses in the vehicle. i can't remember off the top of my head if there is a fuse in the back of the radio or not. you might want to check there too just in case.
