20 Most Recent
Kenwood KDC-MP335 CD Player Questions & Answers
KDC-MP335 security codes
Pueden alludarme tengo un stereo Kenwood kdc mp335 no puedo configurar la salida para el aux au que el stereo trae la salida en la parte de atr?s????
1/22/2020 10:21:40 PM •
Kenwood...
Answered
on Jan 22, 2020
I have no idea how
i was in a similar situation today luckily i was able to figure out the solution follow this 1.switch to STANDBY MODE using the power button on the remote or using the SRC button on the player itself 2.Once you are in the standby mode , press the MENU button ( bass button ) on the left hand side top corner for 1 second 3.Use the right control Knob up and down to switch to CLK ADJ mode . 4.Once you are in CLK ADJ mode Hold the right control Knob for a second until the time starts flickering for change 5.Use the right control knob to change the settings , up and down changes the hour and , left and right changes the minutes 6.Press the MENU button ( bass button ) to save and exit 7.ALWAYS MAKE SURE YOU ARE IN STANDBY MODE hope this helps :)
1/25/2013 6:23:57 PM •
Kenwood...
Answered
on Jan 25, 2013
My kdc-mp335 is on protect i need to know how to
First check your speakers and speaker wires to make sure you have no shorts and/or grounds. If your speakers and speaker wires are fine, try pressing the reset switch if there is one. It should either be a pencil tip sized indentation somewhere on the face (it will not be marked) or behind a small hole on the subpanel behind the face. If there is no reset switch, you can reset it by disconnecting power to the radio for a few seconds. You can do this by disconnecting one of the battery cables if you can't get to the back of the radio. If that doesn't work you probably have a bad output ic.
9/29/2011 7:16:56 PM •
Kenwood...
Answered
on Sep 29, 2011
Demo mode
on my sportster 5 I held down Menu and Display together for 5 seconds to unlock the demo mode
7/15/2011 12:46:26 AM •
Kenwood...
Answered
on Jul 15, 2011
I have no manual for
You can download the manual at
http://www.kenwoodusa.com/UserFiles/File/Global/Consumer/Manuals/KDC-MP3035.pdf
3/30/2011 6:03:32 PM •
Kenwood...
Answered
on Mar 30, 2011
How do you wire a
Standard radio color code as follows:RED=switched ignition +12v YELLOw=+12 volt battery(always hot), BLACK= ground, BLUE=remote turn on for amp, OrANGE=light dimmer, White and white/blk= left front , gray and gray/blk= right front, green and green/blk=left rear, violet and violet/blk= right rear
2/10/2011 12:52:38 PM •
Kenwood...
Answered
on Feb 10, 2011
Hello i get no sound from cd or mp3
are you using an amplifier? if so you may be using the antenna remote turn on wire (blue) instead of the amp remote turn on wire (blue/white).
11/15/2010 5:53:47 PM •
Kenwood...
Answered
on Nov 15, 2010
