20 Most Recent
Linksys CIT300 IP Wireless Phone Questions & Answers
My CIT 300 stopped Skype
If you are a Skype customer, you can contact +18002044427 live chat support as follows: ... Can I transfer Skype subscriptions or Skype Numbers to another Skype account?
"please upgrade your operating system"
I had the same problem. Bought a CIT300 off ebay. Cisco/Linksys no longer provide drivers for this device. I'm running Windows 7. I downloaded a driver from Softpedia, says it is from Microsoft dated 7/12/13 version 6.1.7601.18208. It solved my problems. Hope this helps.
MY LINKSYS CIT 300 MUST
your question is not clear but you may get a user
manual here. otherwise, please post back with a little more explanation of your problem and i assist you further.
Regards
Language problem
Please follow the instructions below to set the unit to English
When powering the phone on select a language such as German.
in the German menus select menu
select display
select language
English will now be available to select.
Cit300 ip phone problem installation
Make sure to use the driver for Vista
here
* Just look for CIT300 and download the 32bit driver.
* Make sure to uninstall the previous installation you did.
* Unzip the download file
* Run the setup_web CIT300.exe file and just follow the installation instructions.
Hope this helps! Goodluck!
(02) 82324677
use you Internet Explorer and browse into the quad that is marked on the bottom of the phone unit which should be something like 192.168.1.40 or something like that and go into the config and you should find the number there but it might be somewhere else as I have not had this type of phone I don't know where else to look.
Frontier router
Frontier Router Login at the bottom of the Network Connections window, just below the address bar. Select Wireless Properties from the menu. Locate the Network security key field on the Security tab. You'll see your Wi-Fi network password if you click the box for Show characters.
1/28/2022 7:46:04 AM •
Linksys...
Answered
on Jan 28, 2022
How to Fix Linksys Router Error 2118?
This seems to be a symptom of a configuration error, which can be fixed by resetting the router to factory default. Do this by finding the (often partially hidden) reset button on the device, and pressing and holding down the button, with the power on, till lights start flashing on the router. Let go of the button and allow the router to reset (can take a minute or two). You will now have reset the router to factory default. To connect to your ISP, you'll need to enter your account details (and any other specific information) provided to you by your ISP. You will also have to set a name and password for the wifi section of your router (if it has wifi) if you don't want it to be freely accessible by everyone within wifi range.
7/29/2021 11:33:41 AM •
Linksys...
Answered
on Jul 29, 2021
