20 Most Recent
LG BH100 Blu-Ray Disc Player Questions & Answers
Lg bp300 blu ray won't play netflix
Since Netflix is an online service and doesn't require the use of an optical eye to scan information from a disc,but rather to stream the data across a TCP/IP network, it probably would be a good idea to check firewall settings. Does Netflix work on another system connected to the same internet source?
Blu rayplayer says check the cord
The internet connection inside the unit is not responding, if new! return it, If that is not a option, it will need to go in for service.
I'm trying to program a
Hello
There is no setup codes for Blu-Ray players came out till now. Very sorry to say that, no universal of other remotes can be used with any brand of Blu-Ray playes, except their original ones. Likeways, no region hack codes also not available with Blu-Ray players, till now. I can't predict the future. I too looking for such codes. OK.
I have a Sony Blue
If you have one movie that it wont play, check to make sure the software/firmware is up to date. There are sometimes updates that fix issues like that.
Blue ray player will not
an upgrade or an update? If it needs an update then it probably has an ethernet port for you to hook it up to your router and it should download the update and install it.
I have an LG BH100
This is the latest available firmware for your player - v100329 . If you already have it then there isn't any newer one to upgrade to - see here
http://www.lg.com/us/support/product/support-product-profile.jsp?customerModelCode=BH100&initialTab=documents#
None have been released for it because the processor inside the player is too weak for the requirements of the new disks.
