20 Most Recent
Sony KD-32FS170 32" TV Questions & Answers
Kd-32fs170
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
The color sometimes bleeds and takes over the
Hello
You are reporting about color "spreading" I thinks. That is colour spred like taills along with picture. Red colour will show it more. There are 2 main couses for this fault. The first one is picture tube aged. The second one is low video output drive voltage. As your TV is new [I can say as it is only four yerars old], the second stated may be the fault.
Check the video output supply voltage. This voltage point can be located at the base card [a square or rectangular printed circuit board pluged into the neck of the picture tube]. It should be above 250VDC. If it is there come to the Red_Blue_Green cathode of the picture tube, [they are all also in the base card itsef]. All this voltages are almost equal to each other, provided 2 or 3 volts difference is normal. If any of them is found too low than normal, check the related videou output transistor. Check the electrolytic capacitor [usually 10MFD or so, 450v] connected to the video output voltage supply rail, and normally can be located at the base card itself. Ok
Keep children away from you, when you open the TV. Be caucious, as 25KVDC [25,000VDC] points are there inside your tv. Keep an adult beside you as a precaution. Never touch any internal part of the tv while it is switched on. Plug it out from the mains socket before doing any componet replacement, except for voltage measurements. Do wear a plastic or rubber footware when you work, and never use a metal chair.
Sony tv turns off
ahh..the 16 blinker..that's a clear sign that your control board is having a terrible 'hair' day. How old is the TV?
I NEED CODES FOR MY NEWSTAR NTR-B28Z FOR MY SONY TV
ChatGPT 3.5
User
I need code for newstar ntr b28z for my Sony tv
ChatGPT
Unfortunately, I can't provide specific code for your Sony TV remote without knowing the exact model number. However, you can usually find the code in the user manual of your Sony TV or by contacting Sony customer support. Alternatively, you can try using the auto-search feature on your newstar ntr b28z remote to find the correct code for your Sony TV.
User
ChatGPT
To find the code for your Sony TV using the Newstar NTR B28Z remote, you can try these general steps:
Turn on your Sony TV.
Press and hold the "TV" button on your Newstar remote until it blinks twice.
Enter the code for Sony TVs. Some common Sony TV codes are: 0000, 0011, 0080, 0111, 1234. If none of these work, you can proceed to the next step.
Press the "Power" button on the Newstar remote. If the TV turns off, the code is correct. If not, try a different code.
Once you've found the correct code, press the "TV" button again to lock it in.
If none of the provided codes work, you might need to consult the manual of your Newstar remote or contact their customer support for assistance.
