20 Most Recent Sony BRAVIA DAV-HDX267W Theater System with Wireless Speaker Kit System Questions & Answers
No sound when trying to connect PS3 to DAV-HDX275
It's likely the sound settings on one or more of your items are not set right or switched off.
10/18/2017 3:30:12 PM • Sony BRAVIA... • Answered on Oct 18, 2017
2answers
What is the code to program my sony surround sound
Try looking here for the model of the Comcast remote you have:
http://www.comcast.com/corporate/customers/customer_support/remotes.html
11/18/2015 3:48:55 PM • Sony BRAVIA... • Answered on Nov 18, 2015
Push power protector
Do a cold reset, page 90 of your manual. Push power button, stop button and disk eject at the same time. Wait 5 minutes and turn back on. Look on page 90 of the manual. This worked for me after trying over a year. I beat I didn't have 25 hrs on mine. Good Luck
2/17/2014 8:54:08 PM • Sony BRAVIA... • Answered on Feb 17, 2014
2answers
Protector and "push Power"
Please check speaker wires should be properly connected and not touched / shorted.
Push Power Protect is error sign when unit got problem in Power Amp area and mostly its Power Amp Out IC failure.
I would suggest to ask Sony for warranty cover.
2/17/2014 8:46:30 PM • Sony BRAVIA... • Answered on Feb 17, 2014
Sony bravia wireless speakers won't pair? ANy answers?
You might try setting the wireless to a different channel. Mine did not work at all on "A" but worked fine on "B".
12/13/2013 1:09:06 PM • Sony BRAVIA... • Answered on Dec 13, 2013
Sony dav-hdx265- disc is stuck- door will not open
According to the Sony manual, a C-31 error code indicates that the disc is not inserted correctly. Their recommended fix is to restart the system and re-insert the disc correctly. That just leaves the problem of getting the disc out, right? If eject doesn't work, you may have to open the disk drawer manually. With single-disc systems this is fairly simple: there is always a small pinhole near the disc drawer, usually just below the right side of the drawer. Straighten a paper clip and stick it into the hole until the latch releases, then remove the disc and close the drawer. All should be fine from there on. I do not know if multi-disc systems have the same sort of release but that is where I would start.
11/24/2013 2:52:34 AM • Sony BRAVIA... • Answered on Nov 24, 2013
3answers
I need device codes
It seems like most (maybe all) Sony HTIB do not work with the Comcast Custom Remote. I've found a work around that fixes the volume control and power button though. Hope it helps you all. I have a DAVHDX275 but I think this will work for most Sony HTIB systems.
What you need to do is steal some codes from a like product and then hardcode in the changes you need to the comcast remote. Set your AUX to 21232 (a sony code for TV/VCRs).
Then do the following:
1. While still on AUX, press and hold SETUP again until the remote blinks twice
2. Type 994
3. Press and release SETUP
4. Type 32975
5. Press and release VOL+
The remote should blink twice. That should reprogram the VOL+ to work with your Sony HT device. For each of the following function codes, follow the same steps and use the codes listed below:
Vol+ = 32975
Vol- = 31951
Power = 32719
Good luck. Let me know if it works.
10/30/2013 10:31:04 PM • Sony BRAVIA... • Answered on Oct 30, 2013
4answers
Code for Comcast remote for Sony DAVHDX275
2. Type 994
4. Type 32975
Vol+ = 32975
Vol- = 31951
Power = 32719
7/11/2013 1:36:18 PM • Sony BRAVIA... • Answered on Jul 11, 2013
0answers
Hi I am unable to program my COMCAST remote to
These directions also work for Sony DAV-IS10It seems like most (maybe all) Sony HTIB do not work with the Comcast Custom Remote. I've found a work around that fixes the volume control and power button though. Hope it helpsicon1.png you all. I have a DAVHDX275 but I think this will work for most Sony HTIB systems.What you need to do is steal some codes from a like product and then hardcode in the changesicon1.png you need to the comcast remote. Set your AUX to 21232 (a sony code for TV/VCRs).Then do the following:1. While still on AUX, press and hold SETUP again until the remote blinks twice2. Type 9943. Press and release SETUP4. Type 329755. Press and release VOL+The remote should blink twice. That should reprogram the VOL+ to work with your Sony HT device. For each of the following function codes, follow the same steps and use the codes listed below:Vol+ = 32975Vol- = 31951Powericon1.png = 32719Good luck. Let me know if it works.
10/16/2012 4:58:32 AM • Sony BRAVIA... • Answered on Oct 16, 2012
DAV-HDX265 dvd tray doesnt open
Probably the gear that opens and closes the drive is broken, Also have to check the belt is correctly placed on the gears.
You have open the player to find the exact reason.
Also check this link for help....
http://drnathan.teamhackaday.com/2009/02/04/xbox-360-samsung-dvd-drive-repair/
Let me know the status.
Thanks
Kevin
7/8/2012 8:19:47 PM • Sony BRAVIA... • Answered on Jul 08, 2012
0answers
Not all my speakers sound
Most inputs are not true 5.1 surround; with the exception of the mic and many movies. You will not have all of them working from, say an ipod or TV unless you choose a sound mode that mimics 5.1 or grater from a 2.1 source. These are modes like Pro Logic (1&2) and often "entertainment mode" or something simmilar that plays the sound out of all 6 channels.
3/18/2011 12:38:06 AM • Sony BRAVIA... • Answered on Mar 18, 2011
Where is the digital optical
Register and download the manual for free at retrevo.com http://www.retrevo.com/support/Sony-DAV-HDX267W-Home-Theater-Systems-manual/id/2727ci276/t/2/ It doesn
2/27/2011 3:12:28 PM • Sony BRAVIA... • Answered on Feb 27, 2011
How do connect my speakers so that i can hear them
To hear the TV system through your Sony unit you will need to connect a RCA type lead from the AUDIO OUT sockets on the back of your TV to the AUDIO IN sockets on the back of the Sony unit. These types of leads are readily available in lots of stores and usually have a red, white and yellow connector on each end. You will only need to connect the red and yellow leads and they should be clearly marked on both units.
You will also need to set your SONY unit to AUX mode but you will not get proper Surround Sound.
1/23/2011 11:01:16 AM • Sony BRAVIA... • Answered on Jan 23, 2011
Why do my tv screen appears in three sections when
hi,
check is your tv supports progressive scan, if not switch off the progressive scan mode on your sony home theater system.
For switching off the progressive scan mode do the following in ur home theater's remote.
Do this setting if your connected the component video
1. Press the FUNCTION BUTTON on the remote.
2.Press the VIDEO FORMATE button to select interlace scanning.
If you are connected the HDMI then do the following setting
2.Press the VIDEO FORMATE button to select the resolution
Select 720 * 480p
1/17/2011 8:36:10 AM • Sony BRAVIA... • Answered on Jan 17, 2011
Sony BRAVIA DAV-HDX267W Theater System with Wireless Speaker Kit System Logo
68 questions posted
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
ZJ Limited
ZJ Limited
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Audio Players & Recorders
Most Popular Question
protector push power
  • Audio Players & Recorders
