20 Most Recent
Nikon Nikkor 18-135mm f/3.5-5.6G ED-IF AF-S for Digital SLR Questions & Answers
Just had a 18-135mm Nikon
At longer focal lengths, when the aperture is smaller, and in low light, many A/F zoom lenses struggle. Is it OK outdoors in daylight ? If so, lens is OK.
My Nikon Nikkor 18-135mm f/3.5-5.6G ED-IF AF-S for Digital SLR lens does not seem to auto focus well. Sometimes the lens will focus and unfocus and refocus constinely. Is this normal??
You did not say which camera body you are using, but you probably have three different auto-focus modes on you camera. You might be using the wrong one.
The modes are as follows:
AF-A Mode: Camera automatically selects single-servo autofocus when AF-A subject is stationary, continuous-servo autofocus when subject is moving. Shutter can only be released if camera is able to focus.
AF-S Mode: For stationary subjects. Focus locks when shutter-release button AF-S is pressed halfway. Shutter can only be released when in-focus indicator is displayed.
AF-C Mode: For moving subjects. Camera focuses continuously while AF-C shutter-release button is pressed halfway. Photographs can be taken even when in-focus indicator is not displayed.
Auto focus no longer working in the range of
This lens has a five yr warranty, As long as it doesn't have impact damaged and you have the receipt just sent it to Nikon NJ, If it was dropped the optical encoder is bad. Tony
Connection between 28-135 nikkor lens and my nikon D70s camera
First you need to tell me where you got a nikkor 28-135 - I dont find any reference to that piece of glass on the nikon site - I believe you might have a sigma or some other brand glass but not NIKKOR... TO your problem - have you tried setting the f-stop to f22? Most lenses talk to the camera bodies via f22 - if not try opening the lens up to its widest setting - typically when you see an F flashing it is because the f stops have been moved off of the AUTOMATIC SETTING - have you tried using the camera in manual mode?
I have this lens on a D50. At times, it does not
Double check to make sure that the camera/lens is not set to manual mode. The next item would be to check would be to clean the contacts of lens, where it attaches to the body. Try the camera with another AF-S lens. It may be that the autofocus unit on the lens has stopped working.
Nikkor AF 18-135 lens won't retract fully
The Zoom ring maybe stuck on something, or not aligned properly
Try sending it to PhotoTech Repair Service in NYC. They are Nikon authorized, and can do the repair under warranty if you still have it. Also if you join they're facebook page, they will give you a 10% discount.
Here is the facebook page link, it has everything you need to send it in.
http://www.facebook.com/pages/New-York-NY/PhotoTech-Repair-Service-Inc/102527215194
Will not focus right, making loud noises.
Your motor may have gone bad. If it makes a loud squeaking noise, it is definitely the motor. Try sending it to PhotoTech Repair Service in NYC. They are Nikon authorized, and can do the repair under warranty if you still have it. Also if you join they're facebook page, they will give you a 10% discount.
Lens will not auto focus any more.
Hi there!
I experienced the exact same problem with my 100-300mm lens and I was never able to get it to work correctly again. In fact, attempting to use it further seemed to exacerbate the problem.
The further you zoom, the wider the aperture opens allowing more light for the camera to focus properly. If the aperture mechanism is damaged, the auto-focus process may not work as it should; which would explain why the auto-focus feature works only when at 18mm.
Regardless, I strongly recommend you discontinue use of the lens until a professional technician can examine the lens and figure out what's going on. I'm sure you can contact the manufacturer to open a support case or you can find a camera store that offers repair services.
I hope this helps!
Pictures are white after taking a shot. But when I'm in indoors it's quite normal.
Way, Way Over exposed Gracey. Read the manual for the mystery Nikon Camera and set the camera to Automatic Exposure. Film 'Speed' is measured in ASA Rating, 200 ASA would be standard for outside, 400 ASA for lower light, up to 1200 ASA for very low light like candle light. The higher the ASA Rating, the more grain you will get in an image. In the old days, we used a light meter set to the actual film speed of the roll of film in the camera and the sensor in the light meter told you what to to set the lens aperture and shutter speed to. Now with digital cameras, it is all automatic, or you can choose to go with manual exposure.FULL 'make model (what it is)' in all questions please first 3 words.GoogleNikon (model) manualRead it it LEAST 3 times and at least once with the camera in your lap. Use the camera every day for a week and read it again...
I encounter a problem r07 using my Nikon D3100 with 18-55mm kits lens or my 55-200mm lens. How can I fix this? Thank you.
On Nikon cameras this isn't normally an error code. Have you got a memory card in the camera? Check that it isn't nearly full.
r07 common comes up as an information prompt referring to the memory space in the camera. '07' being 7 shots remaining.
If the card isn't full try this. Turn the camera off. Remove the battery. Remove the memory card. Leave it like that for at least 15 minutes. Connect the memory card to a computer or a laptop and check you can still look at and move the images that are on there. This is to check the memory card isn't corrupted (developed a fault).
