20 Most Recent Sigma APO 50-500mm F4-6.3 EX DG/HSM Lens Questions & Answers
Sigma 50-500mm auto focus problem
Hi is the manual focus working from inf to close focus and not stoping then it needs a new hsm motor
12/26/2013 5:28:17 PM • Sigma APO... • Answered on Dec 26, 2013
Get barrel unstuck
there is lens lock slider, slide to unlock the zoom.
7/28/2013 1:40:01 AM • Sigma APO... • Answered on Jul 28, 2013
SIGMA CAMERA LENS 50-500MM 1:4-6:3 APO HSM EX FOR CANON
Any digital single lens reflex camera body , rebel t3i, go to Canon's USA website and look at dslr cameras
10/20/2012 2:08:54 PM • Sigma APO... • Answered on Oct 20, 2012
I have a Sigma 50-500mm
Sounds like the autofocus motor is having issues, I'd suggest contacting Sigma.
5/10/2011 8:43:11 PM • Sigma APO... • Answered on May 10, 2011
On 250mm onwards the auto and manual focus do not
That is some heavy glass.. it sounds like there is a problem with the drive mechanism in the lens when the lens is extended. The droop from the weight of the glass prevents the mechanism to function as designed.
Since this is a precision optic, I would send it to Sigma or other reputable shop for a repair estimate. Attempting to disassemble this or contaminating interior parts would worry me too much for me to try it. Unless you know what you're looking for - I'd arrange for service by calling (1-800-896-6858) or contacting Sigma Customer Support, package it up and send it out for repair. You might still be under warranty, too.
3/23/2011 8:18:57 PM • Sigma APO... • Answered on Mar 23, 2011
My 150 - 500 lens will not extend or retract
I'd guess, from when this lens was introduced, that it is out of warranty? My web search did not turn up any reference to what you have described. Whether or not in warranty, I'd suggest starting by contacting sigmaphoto.com to see if they have any suggestions. FWIW, I have the (newer version) 50-500 OS USM on a 7D and am very impressed with it (first non-Canon lens I've bought).
10/16/2010 6:42:07 AM • Sigma APO... • Answered on Oct 16, 2010
2answers
Bigma 50/500
Hey Bob G,
I would try blowing compressed air into the lens to try and dislodge whatever is stuck in the lens barrel. If this doesn't work I would advise you to not take the lens apart. Camera lenses require precise mechanical alignment that can only be achieved with the right tools and the education necessary for achieving it. It would probably be easy to take it apart, but very hard to put it back together. You could try a shim, but you run the risk of damaging the lens further. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
9/13/2009 4:43:41 PM • Sigma APO... • Answered on Sep 13, 2009
2answers
I want to purchase a lens for wild life photography please advice
D 300 is a great camera and compatible with most of the Nikon F mount, Manual, AF or AF-S. You can find a lot of offers in the brand new or used market. Try E-Bay.
7/19/2009 12:58:43 AM • Sigma APO... • Answered on Jul 19, 2009
Lens does not lock into 50mm position........only to 60mm
It problably a loosen tiny piece inside the barrels. Do not attempt disassembly, you can ruin the less. In NY you can get the repair information in BH.
6/28/2009 2:17:26 AM • Sigma APO... • Answered on Jun 28, 2009
Don't know how to switch to manual focus mode.
there is a button on the lense that you switch from auto to manual
5/31/2009 3:03:59 PM • Sigma APO... • Answered on May 31, 2009
2answers
Autofocus motor run but no focus
Found this myself check manual focus ring (closest to camera) maybe ring has moved to "manual"position. This ring moves backwards and forwards between "manual" and "auto" and may need pushing home completely
5/28/2009 4:58:27 AM • Sigma APO... • Answered on May 28, 2009
Soft focus
I would say it is fixable. It could be a couple of different things. Loose optics and/or mount spacing could be the problem. Check here on Fixya to find a repair person in your area.
3/1/2008 1:54:26 PM • Sigma APO... • Answered on Mar 01, 2008
Af-s compatable nikon D-40
You should be able to use any Nikon AF-S or Sigma HSM lens on your D40. If you want to be 100% sure, email or call Sigma from www.sigmaphoto.com. They are generally very helpful with such issues.
1/25/2008 2:54:48 PM • Sigma APO... • Answered on Jan 25, 2008
Zoom lock slide switch
It will only lock the lens in the 50mm position (for storage and carrying) or past 100mm (to keep the elements from making contact when using a tc).
11/16/2007 5:34:43 PM • Sigma APO... • Answered on Nov 16, 2007
Sigma 70-200mm f2.8 APO EX while on Autofocus mode the focus ring moves slightly when half-pressing. Is this normal? is there anyway to fix this?
It is not normal for the focus ring to move slightly when using autofocus mode on the Sigma 70-200mm f2.8 APO EX lens. This could be caused by a problem with the lens or with the camera body. One thing you can try is to check if the lens mount on the camera is clean and free from debris, as this can cause the lens to move when the camera's autofocus system is trying to adjust the focus. You should also check if your lens firmware is updated to the latest version and make sure your camera firmware is also up to date.
1/12/2023 12:18:13 AM • Sigma Cameras • Answered on Jan 12, 2023
Hello All, I need instructions on how to dissasemble the Sigma 300-800mm f5.6 APO EX DG HSM lens to clean an inner element. Does anyone have a service manual/exploded views/parts diagram please?
You can't do this yourself. It needs to be carried out by professionals and is a 'clean room' with service techs in full dust proof protective wear. Send it to them. https://www.sigma-global.com/en/support/ ..
10/5/2022 11:27:10 PM • Sigma Cameras • Answered on Oct 05, 2022
What adapter do I need for a Sigma AF 75-300 lens on a Canon Rebel XTi SLR?
Question edited for clarity. You get the Sigma lens for the camera in Canon fit. https://www.google.com/search?q=sigma+lens+af+75-300+for+canon+rebel+xti Can you use Sigma lenses on Canon cameras? Since Sigma lenses are made to be fully compatible with Canon cameras, they are backwards-compatible. This means that you can use a Sigma lens on a Canon DSLR camera. Similarly, the Sigma cameras are backwards-compatible with Canon lenses. Macro adapter loses the AF feature. https://www.google.com/search?q=sigma+lens+af+75-300+mount+adapter+ring+for+canon+rebel+xti
3/20/2022 12:10:41 PM • Sigma Cameras • Answered on Mar 20, 2022
Where can I find out how to take apart a Sigma 150-600mm contemporary lens?
Taking it apart is not the problem - re-assembling it will be. Unless you have access to an optical laboratory, where laser instruments can measure the exact tolerances required, don't even think about it. You will be left with a pile of optical components, and a far higher repair bill than if you had just let the experts sort out the problem in the first place.
12/6/2021 7:57:17 PM • Sigma Cameras • Answered on Dec 06, 2021
Sigma 18mm f/3.5 - How to open front end to clean?
Best you don't open it at all as you can damage the lens. Send back to manufacture
1/23/2019 4:32:39 PM • Sigma Cameras • Answered on Jan 23, 2019
Sigma APO 50-500mm F4-6.3 EX DG/HSM Lens Logo
25 questions posted
Top Sigma Cameras Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Sigma Camera Expert? Answer questions, earn points and help others
View Most Popular
Sigma Cameras
  • Sigma Cameras
Most Popular Question
sigma camera lens 50 500mm 1 4 6 3 apo
  • Cameras
