20 Most Recent
Visual Land Prestige 7 ME-107-8GB 7" 8 GB Tablet Computer - Wi-Fi ARM Questions & Answers
Fix buffering on YouTube
It indicates that it is downloading the file but it will not download as fast as it is being used. Most systems will stop, but keep downloading until the buffer gets enough and it starts playing again. The buffer is a temporary storage in RAM memory.
How do I reboot my tablet after battery dies?
On most tablets a hard reboot simply requires pressing and holding the power button for about 20 seconds. On some tablets there may be a pin sized hole on the back, try the power button first if not consult your manual before start trying holes.
How to stop videos buffering
Buffering is typically the result of a slow internet connection. This can be at your end of the connection, your ISP or the site you are viewing the video from. You can check your current speeds at http://speedtest.net
Speedtest net by Ookla The Global Broadband Speed Test There isn't much you will be able to do to resolve this, if you are on a slow connection you may consider upgrading your internet connection
All I can get up on my taBLE is colored lines
Probably the screen connector or the screen is broken, goto the store where you bought it to ask if it is possible to repair. If it
is less than 2 years old, the store should repair it under the warranty.
Should I, register the tablet now???
HI jean,
Can i ask you why you are hestant about this? Most warrenties require that the product is registered before they would honor this.
I would register it in case your have any issues or want to return it etc.
Ill follow this post and if you want any assistance please let me know.
Good luck
Chadman
Tablet want hold a charge
Charge problems are an issue that is common with ALL tablets. On mine I had to completely back up all my data to an SD card or you can use the cloud if you want. Do this first while it's hooked to a source of power via your usb cord. Next locate the menu option to do a factory reset. This will warn you about deleting all your data. (you've backed it up so... ) proceed. Restart your tablet. Now locate in your menu system the anything that will allow you to disable your manufacturer's graphic user interface and software. restart again. Your tablet will appear different... that's the REAL android interface. Plug your charger in, see if your little battery symbol shows a lightening bolt. Leave it sit for a while and check to see if you have progress.
If you are charging, good! If not, your only recourse is to do a hard factory reset. I'm sorry but I do not know how to do that with your model.
FYI, it very well could have been one of your apps that caused this issue as well as the GUI from the manufacturer. Make sure you get a virus checker, and other security software to protect you.
Good luck
Visual land prestige pro 7 D
It sounds as if the giro control has become faulty. If the unit has been dropped or bumped against something, it could have damaged the free movement and mis-alligned the set points for the giro. Best Wishes
