20 Most Recent
Sabrent TV-PCIRC (TVPCIRC) Video Capture Questions & Answers
The seriel number provided on disk sleeve will not work.
The installation program for the WINDVR 3 program isn't looking for the serial number of the TV Tuner card. It's needing your registration serial number when you paid for the software. I found a serial number that worked for me (after looking for 4 hours!!). Just enter this serial number and it should work for you. Be sure and put something down for your company name, also. Here is the serial:
kC7G94GSAE08A0S
TV-PCIRC software issues
I'm not familiar with your tv card but it may not work in Vista or Windows 7. Usually you have to check hardware requirements and compatibility on the box. And try to by something from known brands like
Hauppauge,
AVerMedia, Leadtek,
PinnacleMost of their new models will work on Vista and Windows7.
You can try to install and run it's software in Compatibility mode as on XP. And run it as Administrator. If it wont help return your card if you can.
Good Luck!
Computer will not recognize card. checked to make
Check device manager and be sure it's not already there, but in an error state (driver issue maybe). I assume you are logged in with an admin account.
any other pci cards installed? - maybe mainboard ng and all pci slots are bad.
Try another pci slot.
Check bios to ensure all hardware is enabled
test the card on another PC for detection.
Hope this helps!
My replacement rc-518m remote control is stuck in TV mode how do I get back to a/v
It may be necessary to take the remote apart and clean the contacts with rubbing alcohol and a tissue on the board that is inside. If that doesn't fix it, a replacement is necessary at Ebay.com https://www.ebay.com/itm/394877786274?itmmeta=01HT47X6X7WE749Y2CMG3NX54S&hash=item5bf08cd8a2:g:7pQAAOSwn7BlAn8h&itmprp=enc%3AAQAJAAAA4OMK5%2BdFWZwJQhIS5nEQ3eO7C2zq5QRICeu%2BbPKwqrfkc8con3byi0%2BbabcDYrBTOEyKclvkbzHrOJ1lVMfwduYTPcx0fAcW5XmaZ3ZRWS1%2FnVxMUIwno%2BPNUVuNqN%2FCSDJJ3gG2hQ%2BbGGyfUiO2ppgtjsvtiihnrClntKtSssM8RikHgpG8y9SjAz6z0V0GPkVJf6gypymGRdzz4HfuNn%2BkiMmAXp2NHVWpP6xfbghej%2B1MkOgqhJxV4V1B%2Bp8wVx%2BKV36M%2FVEdzoejZajCMt9ApRe1beW4a0rCXTdGZRuV%7Ctkp%3ABFBM2u70h9Fj
