20 Most Recent
Rowenta DZ5080 Iron with Auto Shut-off Questions & Answers
Iron leaking and plate dirty
If you have hard water, there will be a buildup of minerals where the rubber gasket on the water tank meets the steam chamber that is built into the sole plate. This will make the rubber gasket surface become hard and no longer seak to the team chamber, resulting in water leaking from the tank onto the outside of the iron.
If you are reasonably skilled with tools and have a Torx T20 driver, you can disassemble the iron and remove the rubber gasket between the tank and the steam chamber and soak it in vinegar to remove the mineral scale. First remove the three Torx screws visible at the rear of the iron and gently pry off the gray rear cover plate. This will expose two screws holding the rear end of the sole plate. Remove those two screws. Then gently pry off the stainless steel nose piece on the front of the iron; this is the curved piece that says "high precision" on it. This will then expose the screw that holds the front of the sole plate on the handle. Remove thqt screw. Pull the black connector at the rear of the iron off the two rods to which it is attached, and you can move the sole plate away from the handle. The rubber piece in the handle that is sort of oval shaped and about 2 inches long is the gasket that is probably causing the leak. Gently remove it and soak it in vinegar to remove the scale, and remove the scle from the round hole where it meets the steam chamber in the sole plate. .When they are clean, reassemble the gasket onto the handle and the sole plate onto the handle, connecting the electrical connections, and replace the screws, It is not simple, but it is doable.
Want to send back for
The Rowenta site can be found here:
http://www.rowenta.ca/rowenta/frame.aspx
To find your nearest Service Centre, click on
Consumer Care on the bottom menu bar and then on
Service Centres on the left side menu.
Before returning for warranty I would recommend you contact the company for instructions. Click on
Contact Us on the bottom menu bar to open a web form.
I read to check the
Hello. The fuse is called thermal fuse, it is a small cylindrical metal, placed in series with one of the main line and screwed and enclosed in an insulator. You can see that inside the iron.
Does the rowenta dz5080 have
You can use
Rowenta DZ 5080 in dry mode ironing when you turn the switch at DRY setting. Take a look at this photo:
This setting is something that you can read at the 6th page of the user manual:
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, accept my solution. Thanks and regards
Stelios
direct
fixya link: http://www.fixya.com/users/technical114
