20 Most Recent
Bosch Nexxt 100 Series WFMC1001UC Front Load Washer Questions & Answers
My bosch wfmc 1001 wont
yes the best person to se would be the engineer or go to the manufactures website and try to get a service manual for it to see an exploded view of the affending item eric
I have a WFMC100UC Bosch frontload washer .it will
there is a possibility that the water censor tube is blocked and wont let the program advance to the next stage, unplug the machine take the water supply off pull out the machine remove the back cover and you will find a small pipe about 5mm across going upward towards the top of the machine, take it off and blow gently into it you should hear a faint click and one when you release if that is the case then go back to the place where you took it from and unblock the small metal pipe with a pipe cleaner or similar item this usually will cure your problem sometimes the washing powder or fluid dose nt clear away properly leaving the hole blocked preventing the control board from activating the wash cycle here's hoping eric
Why doesn't it spin?
Many things stop front load washers from spinning. Such as, it didn't drain all the water, the door is not locking, it is unbalanced, the pressure switch does not operate or there is a hole in the pressure switch tube. The drain pump has a foreign object stuck in the impeller. Just a few to check
How to clean Bosch washer 100 series filter
You have to make sure that the spring part is towards the bottom of the front. If you look closely at the washer at the bottom you will see a groove. That groove is where that spring will need to end up otherwise the whole thing will keep poping off.how I install is I use a 90 degree pick tool. I work the edge of the seal with the metal ring and making sure it lines up with the groove. once there is tension on the spring I streatch it with the 90 degree pick tool and continue to work the rest of the gasket around. Once you get that completed I push down on the spring to make sure that it is in there. If it is not it takes one door opening to make it fall all apart and you have to start over.
