20 Most Recent Lite On LH-20A1H DVD RW Dual Layer Burner Questions & Answers
I burn with windows media but cd wont play in any
hi you lost decoder driver on you pc . you get free software decoder , and get play any dvd/cd . you download free software decoder and install and ready play.
byeeeeee
5/15/2022 12:53:40 PM • Lite On LH-20A1H... • Answered on May 15, 2022
I have a hp pavilion tower with outside face panel eject button, does the lite on have a third wire hook-up on the rear to acomadate for face-cover eject button on my hp tower
I don't understand your question. Let's try again.... what is your problem and include some details.
7/9/2014 9:43:42 PM • Lite On LH-20A1H... • Answered on Jul 09, 2014
Software problem
Nero needs to be uninstalled (using Nero Clean Tool) and then reinstalled after you have added a new lightscribe DVD drive. To correctly uninstall Nero go to Nero website to download Clean Tool application specific to your version of Nero. http://www.nero.com/nero7/enu/Clean_Tools.html
1/8/2014 4:20:58 AM • Lite On LH-20A1H... • Answered on Jan 08, 2014
I put in a dvd/rw
Make sure the discs you are using are compatible with your drive. Some drives will burn dvd - r discs but not dvd + r discs. Hope this helps.
9/19/2013 10:14:17 AM • Lite On LH-20A1H... • Answered on Sep 19, 2013
On my lh-20a1h dvd rw
Check inside the drive just below the tray and make sure the belt is still on the wheels, They are known to break and cause these kinds of problems.
9/19/2013 10:09:36 AM • Lite On LH-20A1H... • Answered on Sep 19, 2013
I have an acer aspire t160 I installed a windows xp pro and my cd/dvd rom door will not open . is there something I can do to get it recognized
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer Close all open programs
Click on Start, Run, and type regedit and press Enter Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak If any of the above keys shown in step 4 are listed, right-click on them and choose DeleteAfter deleting the keys, close the registry editorReboot your computerOpen My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
2/17/2012 9:53:02 PM • Lite On LH-20A1H... • Answered on Feb 17, 2012
This drive does not read
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer Close all open programs
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose DeleteAfter deleting the keys, close the registry editorReboot your computerOpen My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. oryou might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device if your computer came with a motherboard disk the drivers could be on it click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark?! or a red x right click you will need to update the driver or select properties general troubleshoot, select driver click to reinstall drivers click update driver hope this helps
7/1/2011 2:21:25 AM • Lite On LH-20A1H... • Answered on Jul 01, 2011
Problem in burning dvd dual
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or the drivers may have been corrupted or you might have a virus run your antivrus program you might have to physically unplug the leads for this cd/dvd drive restart your computer then plug them back in this should activate the found new hardware wizard or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer Close all open programs
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete After deleting the keys, close the registry editor Reboot your computer Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. hope this helps
5/10/2011 3:25:30 PM • Lite On LH-20A1H... • Answered on May 10, 2011
LH-20A1h not reading at all
you dont need to install any third party software to have it read disks. uninstall that and give it a go, if it still doesnt work the laser may need cleaned
2/25/2011 12:25:48 AM • Lite On LH-20A1H... • Answered on Feb 25, 2011
My lite-on lh-20a1h specs sy it is dvd dl
your drivers may have been corrupted or you might have a virus run your antivrus program you might have to physically unplug the leads for this dvd-rw then plug them back in this should activate the found new hardware wizard or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device click start control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you will see options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall make sure that the cd-dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or if this does not fix the problem it might be a registry problem Close all open programs
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak If any of the above keys shown in step 4 are listed, right-click on them and choose DeleteAfter deleting the keys, close the registry editorReboot your computerOpen My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. hope this helps
1/31/2011 12:26:48 AM • Lite On LH-20A1H... • Answered on Jan 31, 2011
My Lite-On DVDRW -LH-20A1L
Hi Mhlato,
    • Download and install CCleaner (free) from Piriform
    • Run the cleaner to remove old un-needed temp files
    • Select the StartUp tab and look for any programs that you know you installed but no longer use or need, and disable them. Caution, do not disable any system files unless you absolutely know what they do and that you do not need them.
    • Run the Registry cleaner, when asked if you want to backup the registry, select YES, and save to a file you will remember just in case. I have used this program hundreds of time on many different system and it has never caused a problem, but you want to be safe, backup the Registry.
    • If asked about a particular file that it wants to clean, select "yes to all"
    • Reboot
Windows should reinstall the drive when the computer boots back up.
If this does not resolve your problem, try the following.
If you take all these step and you still can not play a DVD, chances are your CD/DVD player needs to be replaced. Good Luck,
    • If this helps resolve your issue, would you please rate the solution.
12/30/2010 11:31:54 AM • Lite On LH-20A1H... • Answered on Dec 30, 2010
My LITE-ON DVDRW LH-20A1H ATA
Clean the upper/lower filters:
http://support.microsoft.com/default.aspx/kb/314060
Then, insert your windows install disk and boot.
Does it see that?
If not, your CD laser is gone.
10/29/2010 2:52:11 AM • Lite On LH-20A1H... • Answered on Oct 29, 2010
Lite on drive drawer is sticking. wont open
Sounds as if you may have a disk in there that's lodged between the tray and the inner mechnism. Use the release pinhole, and a small screwdriver or butter knife to pry open the tray, gently. You'll feel it releasing when you insert a straightened paperclip or other small object.
9/27/2010 3:52:31 PM • Lite On LH-20A1H... • Answered on Sep 27, 2010
My pc drive wont open Help!!!
Is the cd/dvd? Look carefully on the front, you'll see a tiny hole just below the Tray (usually beside or above the eject button), take a straightened paper clip or a long needle and push inside the hole while you press the eject button, push it inside until it ejects out.
Good luck.
Thanks for using FixYa.
9/27/2010 3:48:02 PM • Lite On LH-20A1H... • Answered on Sep 27, 2010
DVD recorded refuses to read dbl layer dvd it just burned
try burning the dvd's at a lower speed, most of the dbl layer drives have similar type of problems.
7/29/2010 12:33:20 PM • Lite On LH-20A1H... • Answered on Jul 29, 2010
Where is srvice center in light on dvd writer plz
You can follow the link mentioned below........
http://us.liteonit.com/us/index.php?option=com_content&task=view&id=140&Itemid=186
Please post your feedback and Vote if the problem resovled as per your satisfaction.
7/17/2010 6:20:08 PM • Lite On LH-20A1H... • Answered on Jul 17, 2010
I need to know where to plug in on motherboard
If its having sata connection you can see sata ports on *********** board using sata cable
1.Pic of sata cable
2.Pic of Sata ports on mother board
You can connect any one of the ports. and you need to go to bios and enable the sata ports if its not done already..
If you have a normal CD Drive you can connect with IDE cable.
See the pics below
4/24/2010 3:43:19 AM • Lite On LH-20A1H... • Answered on Apr 24, 2010
Liteon 20xDVD WRITER
Sorry you are having trouble.
It sounds like a bad drive to me.
Try this: take a paper clip and find the small hole in the door,
insert the paper clip and gently push. this will manually open the door
4/4/2010 10:43:18 PM • Lite On LH-20A1H... • Answered on Apr 04, 2010
2answers
How many times can I Burn in a DVD re writable
Hi friend,
You can do may times...there is not limit....if you DVD layer is damage then you can't you in future.....you need to use case for DVD.. it will provide the care for DVD..
3/25/2010 1:09:21 AM • Lite On LH-20A1H... • Answered on Mar 25, 2010
Lite On LH-20A1H DVD RW Dual Layer Burner Logo
Popular Tags
89 questions posted
Top Lite On Computers & Internet Experts
Steve Pack
Steve Pack
Larry Ng
Larry Ng
Are you a Lite On Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Lite On Computers & Internet
Most Popular Question
burn windows media but cd wont play in
  • Computers & Internet
