20 Most Recent Amana 19.6 cu. ft. / 555 liter Upright Freezer Deepfreeze AFU2067AW Questions & Answers
Check the fan vent to see it's not blocked or frozen. Sometimes a defrost will clear ice temporarily, but it will happen again if you have a bad fan.
Amana 19.6 cu.... | Answered on Mar 27, 2014
If you hear the fan then it might be sticking on defrost mode.
Hello.
Yes the door gasket is replacable. If the model number for your freezer is the one listed in your question (AFU2076AW) the part number for the door gasket is 4357120 it could be purchased at your local appliance parts tore or online at;
apdepot.com
searspartsdirect.com
partselect.com
apwagner.com
repairclinic.com
GENE
Amana 19.6 cu.... | Answered on Sep 14, 2011
This is about time I believe your defrost drain has become blocked and is not allowing your defrost condensate to exit your freezer. Click here=> AFU2067AW Drain System Service Information.jpg This will explain just where to begin and Click here=> Leaking Refrigerators Just What may Be Happening Once there click on all of the links and read just what it will take to solve this problem. If you have any questions please ask. Please rate these solutions, Thanks, Sea Breeze
Amana 19.6 cu.... | Answered on Mar 28, 2011
The excess frost in those areas is probably caused by leaky door gasket seals. They should be tight enough to hold a dollar bill securely all the way around. A defrost problem would start on the coils behind the back cover inside the freezer and would also appear on the back wall before it did on the door edges.
Amana 19.6 cu.... | Answered on Jul 13, 2009
Seems like a clog somewhere calcium deposits
Amana Freezers | Answered on Mar 18, 2019
Unless you have a lot of expensive refrigeration tools and a license to recover and buy freon, then you need a serviceman.
Amana Freezers | Answered on Dec 21, 2015
No if you did work for few month
Amana Freezers | Answered on Dec 02, 2014
Frost will normally build up if you do not have frost free freezer and in which case it is possible the frost free system is faulty. If it is not frost free then it has to be defrosted a few times in a month. However if the frost comes up very quickly then there are possible causes.
You may be having leakage from the door seals or there are items in the freezer that are not properly covered to avoid moisture escaping. Other possibility is that your freezer is set too cold and there are not many items in it.
Amana Freezers | Answered on Aug 18, 2014
Your drain line is clogged. Take a small diameter pice of wire and snake out the drain line from inside the freezer.
You may have to access the back rear near the compressor and separate the drain line there and clean it further.
Amana Freezers | Answered on Jul 02, 2014
Amana 19.6 cu. ft. / 555 liter Upright Freezer Deepfreeze AFU2067AW Logo
9 questions posted
Top Amana Freezers Experts
John Tripp
John Tripp
Dennis Boxerman
Gil Shultz
Are you an Amana Freezer Expert? Answer questions, earn points and help others
View Most Popular
Amana Freezers
  • Amana Freezers
Most Popular Question
self defrosting deep freeze not
  • Freezers
