20 Most Recent Amana Freezer DeepFreeze AFU1767BW 30" 16.8 Cu. Ft. Upright Freezer w/ Free-O-Frost¿ Questions & Answers
Seems like a clog somewhere calcium deposits
Amana Freezers | Answered on Mar 18, 2019
Unless you have a lot of expensive refrigeration tools and a license to recover and buy freon, then you need a serviceman.
Amana Freezers | Answered on Dec 21, 2015
No if you did work for few month
Amana Freezers | Answered on Dec 02, 2014
Frost will normally build up if you do not have frost free freezer and in which case it is possible the frost free system is faulty. If it is not frost free then it has to be defrosted a few times in a month. However if the frost comes up very quickly then there are possible causes.
You may be having leakage from the door seals or there are items in the freezer that are not properly covered to avoid moisture escaping. Other possibility is that your freezer is set too cold and there are not many items in it.
Amana Freezers | Answered on Aug 18, 2014
Your drain line is clogged. Take a small diameter pice of wire and snake out the drain line from inside the freezer.
You may have to access the back rear near the compressor and separate the drain line there and clean it further.
Amana Freezers | Answered on Jul 02, 2014
Amana Freezer DeepFreeze AFU1767BW 30" 16.8 Cu. Ft. Upright Freezer w/ Free-O-Frost¿ Logo
1 questions posted
Top Amana Freezers Experts
John Tripp
John Tripp
Dennis Boxerman
Gil Shultz
Are you an Amana Freezer Expert? Answer questions, earn points and help others
View Most Popular
Amana Freezers
  • Amana Freezers
Most Popular Question
amana afu2067aw 19 6 cu ft standup
  • Freezers
