20 Most Recent
Logitech FreePulse Wireless Consumer Headphones Questions & Answers
Headset not powering
I had the same issue. I called logitech and they replaced the entire kit with the latest model with Bluetooth, So i sorta of got a free upgrade.
1/12/2017 8:12:02 AM •
Logitech...
Answered
on Jan 12, 2017
Samsung's yp-t10, can it be paired with freepulse?
Yeah, they were quite well together i have them both.
To connect
1. Hold the switch button on the Free pulse until it flashes
RED & BLUE
2. Go to bluetooth setting in the T10 and add Headphones
3. Turn on headphones when turning on T10 should automaticaly connect.
12/20/2016 8:20:25 AM •
Logitech...
Answered
on Dec 20, 2016
Logitech Freepulse headphones won't turn on
There is a reset button on both the headphone and the transmitter. Try to reset them both before attempting to pair them again. Since the led won't turn on there is a possibility that the battery is not charging. Is the orange light working when the headphones are charging? It should be and then it should turn off when the battery is full.
8/22/2014 5:43:01 PM •
Logitech...
Answered
on Aug 22, 2014
Logitech freepulse headphones not charging?
Same Problem, Headphones will charge but they wont turn on no matter what you do. Called, got them replaced, so I thought hmmm I can figure out what went wrong with the old ones.
It is the switch itself. The connection next to the charging plug does not make contact anymore. It is a weak point and after putting excessive force on the power button it actually twists the switch enough to beak the solder joint. DO NOT LIFT THE SWITCH ITSELF! Just solder the one next to the charging plug and it will be good to go.
To take them apart is a pain. Remove foam by pulling on it. Remove tiny torrx screw (CR VT-6, bit I used), then remove (actually pry up) silver "ring" at the point where the band meets the ear piece. Finally, pry apart at the band section. I used a razor blade. It is 4 tabs on the inside and is a pain, but came apart. Then take 2 screws out to remove the band and there is the board.
Solder the switch next to the light and charge plug and it is good to go.
Hope this works,
Ryan R. Gerner
4/9/2013 1:02:04 PM •
Logitech...
Answered
on Apr 09, 2013
My Freepulse headphone won't pair anymore. Both
You hold the button on the transmitter for about 50 seconds - light flashes red, solid red, goes off and then flashes blue and red. Then you can do the same on the headphones. Then wait and they should pair.
11/13/2010 6:03:30 PM •
Logitech...
Answered
on Nov 13, 2010
Connection
Thank you SO much , i know this is old, but i recently had mine repaired and i thought i'd have to do it again but you saved me a weeks worth of stress, and renewed my faith in logitech, as if i EVER doubted them <3333
2/26/2010 6:44:20 PM •
Logitech...
Answered
on Feb 26, 2010
The headpiece and the computer piece won't synch
Uninstall the software that came with your headset if indeed any did. Failing that, I 'm assuming this is a blutooth headset. Check your PC has latest bluetooth drivers and updates, reboot and reconnect your hardware
10/16/2009 3:50:00 PM •
Logitech...
Answered
on Oct 16, 2009
